RV.Net Open Roads Forum: Technology Corner: help lost all but one channel
 > help lost all but one channel
ADAD437
New Albany,Ind. USA
Posted: 06/10/12 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
am running off antenna and the winegard entertainment switch box.i am getting 12 volts out to the antenna,after a storm went thru south dakota last night i lost all but one channel. any ideas and help appreciated. many thanks in advance.
James,Gail & Pancho
2005 georgie boy Pursuit
Mandalay Parr
Phoenix, AZ
Posted: 06/10/12 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe the amplifier in the antenna head went south or got wet.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
jorbill2or
Oregon
Posted: 06/10/12 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
My bet your antenna has moved and isn't pointing in the correct direction do you know if it's moved ?
My post's are my opinion The advice, comments etc are free and worth what you paid
Bill
ADAD437
New Albany,Ind. USA
Posted: 06/10/12 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for the replies talked with a neighbor and he lost them all too. so i guess it is wait and see. Or don't see.LOL
othertonka
Stockton, CA
Posted: 06/10/12 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
Could be all the channels broadcast stations were damaged and went off the air except the one you are getting
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
billb1
Fort Erie, Ontario, Canada
Posted: 06/11/12 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Also check if you have 12v at the antennae. Water might have gotten into one or more of the connections going the to the ant. and is causing a bad connection.
Had a problem with my rooftop ant. and found the connections corroded. Cleaning or replacing them fixed the problem.
BillB
2000 Dodge Ram Quad Cab 1 Ton Diesel, 4.10 axle w/limited slip, auto trans.
2000 Real Lite Truck Camper
M GO BLUE
Southgate, MI
Posted: 06/11/12 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Have you tired to reprogram your TV?
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
