RV.Net Open Roads Forum: Tech Issues: computer fans for fridge
 > computer fans for fridge
nvreloader
Western Nevada
Posted: 06/11/12 01:43am Link  |  Print  |  Notify Moderator
I wired my 4" square external dual fans (in the vent area), with an 85* snap switch, comes on at 85* and stays on untill the outside temps drops below 85* then goes off, also have a switch to shut it off permanately if needed.
Sure makes a difference on keeping the reefer cooler, also have a dual Blue fan inside wired to the hot wire in the curcuit board, since the newer reefer Nor Cold have magnetic door switches for the internal lite now.
Don
2010 F-350,6.4PSD, 6spd man trans,CC,SWB,SRW, Caravan camper shell,50 gal bed tank,17,000lb Husky WD hitch,Northwoods 2008 28KS Desert Fox Toy Hauler,2005 Honda 500 Rubicon ATV w/rumble seat,1 Aussie waiting,watching and ridin shotgun on the whole outfit.
rk911
Wheaton IL
Posted: 06/11/12 06:33am Link  |  Print  |  Notify Moderator
SidKaye wrote:
My Interior fan is wired to the fridge light....NO HOLES. There are lots of pics already posted, try a search.
Sidney
not all RV fridges have constant 12-volts at the light. my Norcold N841 is one of them.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
Dave H M
IL
Posted: 06/11/12 07:21am Link  |  Print  |  Notify Moderator
rk911 wrote:
Sidney
My interior fan gets its juice from the hot side of the interior frige light switch
jauguston
Bellingham, WA
Posted: 06/11/12 08:03am Link  |  Print  |  Notify Moderator
Tuna,
No I don't remember what the temperature was or if the ad said what it was other than they were lower than the stock switch. You can probably find his ad on ebay. I also use the hot side of the inside interior light for fan power for the dual blue fans.
The two switches in the center of the support bar are two way- down for thermostat control and up for manual. One switch controls the lower two and the other one the upper two that lay on top of the fins.It doesn't really show in the picture but the fans are on about a 45 degree angle pointing in and up.The manual option on the power switches I find was unnecessary and is never used.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Wherever I happen to park
Posted: 06/11/12 10:02am Link  |  Print  |  Notify Moderator
I put a computer fan inside NO HOLES REQURED I tapped the light power lead, There are two ways to do this, wire across the switch and door closed = fan on, wire across the entire assembly and the fan is always on.
For the otside fan.. I found the outside end of the very same wire I used inside, yes, it goes out and hooks to the connections board.
bob213
Fresno, CA
Posted: 06/11/12 11:31am Link  |  Print  |  Notify Moderator
If you have the upper access panel that you can get above the refrigerator coil behind the refrig. you may be able to use this setup. It was posted on another forum. 4-48cfm fans that you could hook up individually or all together. Great price and 192cfm if you have the room for it.
rear fans
mapguy
Puget Sound
Posted: 06/11/12 12:18pm Link  |  Print  |  Notify Moderator
rear fans
Can you provide a link to that forum thread!
pianotuna
Regina, SK, Canada
Posted: 06/11/12 10:25pm Link  |  Print  |  Notify Moderator
Hi Spike99,
Nice install. How about adding a snap disk or other thermometer to your modification?
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
spike99
North America
Posted: 06/11/12 09:26pm Link  |  Print  |  Notify Moderator
If "outside" the fridge, do investigate:
Store Bought at:
- Click Here -
- Click Here -
For 10mm 12V Computer fan with manual off/on switch install method (that I installed on my fridge's rear panel), see:
- Click Here -
- Click Here -
If wondering, I'd install the computer fan again. It was low cost and very easy to "make fit" into the rear of the fridge.
Note: Remember to install a manual off/on switch as well. Thus, one can "turn the fans off" - if they keep folks awake at night.
