Looks like I'll being searching for a low mileage 2008 with a exhaust break,Dodge doesn't make the quad cab with a diesel anymore.
There is absolutely nothing wrong with the 6.7.....it pulls like a locomotive. The only advantage of the 5.9 is that they are older and have less emission equipment on them and the usually get a little better mileage. As with any of the newer diesels, regardless of the brand, the emission equipment can be a bit finicky.
Sam
2001.5 Dodge QC2500 coal burner, 6spd,BD brake,a pile of other stuff!
little black box, K&N'd,only smokes a little....
2008 Thor Jazz 2870UK 5er
Beacher50 wrote: Current TV is 2008 Silverado crew cab, 5.3L, it was fine in the Midwest, but now that I'm out here in the true west, I'm not really happy with its performance up and downthe grades. I'm towing a TT, Grey Wolf, 30ft, 6500lbs dry.
I'm debating going to a Cummings diesel ,or at least Hemi, or GM 6.0. What is the torque difference between the 3?
One constraint I have is vehicle length, I can't go past 230 inches total TV length, it won't fit in the garage, and it must fit.
Dodge quad cabs will fit.
New or used? If used, a pre-2008 (5.9) Cummins or a pre-2007.5 Duramax. New? Gas (5.7 Hemi or GM 6.0) all the way.
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
Beacher50 wrote: Ok thanks, and sorry for the Cummings vs Cummins.
LW wants a diesel, has she is uncomfortable when the chev is cranking on steep grades. (I'm one lucky dude is all I got to say about that).
Not as uncomfortable as she will be when she gets the repair bills for some of the new diesels! The Hemi, Ford's V10, or the GM 6.0 will happily run for hours at 3500-4500RPM pulling hills without a hiccup.
Quote: the cruising range is another plus, it seems like I'm always pulling over for fuel in the Chevy, 25 gallons at 9 mpg or less means lots of stops. plus I usually fill up at the quarter tank mark.
I've also noticed some rams pulling TT and TV with aux fuel tanks in the bed, are these connected to fuel system, or so they have to be pumped into the main tank? It wouldbe great to capitalize on low fuel prices when they're present.
Are there any pitfalls to be wary of when considering used Cummins?
Lift pumps on older trucks, engines modified by idiots that broke parts, deleted emission stuff that will mean you cannot register it in Kalifornia, and people demanding premium prices for junkers.
Quote: Lastly, being from the upper Midwest I've developed a comfort factor having 4x4' now that I'm here in The Sacramento area, I'm not I really needing itt, LW likes 4x4 too, but admits she hasn't seen much snow about the valley. And we don't off road.
Personal choice...I plow with my F-350, so 4WD is not optional for me.
Quote: And, what about transmission choice, I see a fair number of manual 6 speeds out there, but an Auto would be better since LW will need to drive if an emergency circumstance develops.
Teach her to drive a 6-speed. It will take maybe ten minutes.
The 6.7 burns more fuel to make less power, and the emission junk can be problematic (like dumping raw fuel into the oil!). I would not own a post-2007 diesel if you GAVE it to me.
Over 11,000 miles now at about 5,000 about a 2 minute forced regen, I think it was a fluke I was towing at the time. Not one other than that. Use it like it is supposed to be and you won't have any issues. San Diego to Indio, CA 9.7 mpg 27,000# combined, try that with a Hemi...NOT!
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
Just got rid of a 2007 Chevy with the 6.0 and 4:11 rear end, driving a 2012 Dodge 2500 with the Hemi and pull with a 2007 Dodge DRW 4x4 Cummins with a manual 6. As the others said, buy the diesel!
If buying used, keep your eye out for a really clean low-miles 04 and newer Cummins. I wouldn't get too hung-up on the transmission, stick or auto will be fine. An exhaust brake is an easy add-on, and worth the money. The main thing, is finding one that has been taken care of and not modified with hot rod junk. As far as the 6.7 and 68rfe trans, I really enjoy mine, and wouldn't go back to my old 5.9 5-speed. Good luck.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
