RV.Net Open Roads Forum: Class A Motorhomes: onan lp generator
pkarpf
az
Posted: 06/11/12 12:21am Link  |  Quote  |  Print  |  Notify Moderator
Our '94 Allegro bus generator does not work. Based on the sounds
it made b/4 it completely stopped working I believe the starter
is shot.
Can anyone tell me how much I can expect for this repair?
Thank you for your help
Tinstar
McKinney, TX
Posted: 06/11/12 12:43am Link  |  Quote  |  Print  |  Notify Moderator
HERE is one for a little over $40. I don't know if it will fit your genset but it's an Onan starter. Others are similarly priced but others are up around $150.
Are you doing the work yourself or paying someone else to change it for you?
Never pass up a chance to go somewhere
pkarpf
az
Posted: 06/11/12 05:21am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, I am not able to do this myself. So yes, I was interested in what a shop might charge.
There are several other things I need done, not huge, but they
may be time consuming.
Thank you.
Pat
PapPappy
Wilmington, NC
Posted: 06/11/12 06:10am Link  |  Quote  |  Print  |  Notify Moderator
I found that I had a lose ground cable on my genset....the cable that bolts to the chassis. It also sounded as if the starter was going...would sometimes start, but was sporatic.
I happened to be at the genset when I was priming/starting it with some SeaFoam in a jug, when I saw some sparks from the ground cable.
Once I tightened cleaned and tightened the cable connections, everything was fine.
You may want to check that first....it will only take you a few minutes, and won't cost you a dime. VERY EASY repair, if you've got a wrench......if you don't, it's worth buying one
Good Luck
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
