mary will
We are towing a Smart Car four tow on all four wheels down it good going down the road but if we turn Right or Left it do not come back in line and cause the car to move with short jerky and twisting wiggle motions. Have to stop and turn the wheels straight. Can someone tell me why ? this is doing it,so we can fix it.
carringb
Corvallis, OR
Needs more Caster!
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
Turtle n Peeps
California
carringb wrote: Needs more Caster!
^^^^ what he said. Pull in 3 or 4 degrees. It'll snap back.
outside the fire"
mary will
What is this caster about it not for my car I am looking for help.
Macktee
Canada
Mary, it sounds like something in the towbar, or baseplate is out of alignment. Has it done the same thing since you started towing it. If so I would take it back to the shop that did it and have them check it out. If you did it yourself, I would take it to a pro and get it looked into. Macktee
04 Monaco Dynasty Diamond 1V ( Homer II)
2012 Ram 1500 4X4 Quad Cab towed
2011 Dodge Journey
2013 Cargo Mate 24ft enclosed car hauler
Tom and DW Nancy
Holliday Trails member
Good Sam Life time member
FMCA member# F419937
Dennis M M
Geneva, IL; Tucson, AZ
Caster is the vertical angle of the front wheel front to back - think of the front wheels on a grocery cart. Not something you can or should mess with yourself. Macktee has the best advice. Sounds like something is binding.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'11 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
mary will
Thank you i will take it back to the shop they put on the towbar and baseplate yes it starting the frist time out.Thank all of you i hope this will fix it.
jmckelvy
North Alabama
Does the car have a steering wheel lock position in the ignition key? If it does you are remembering to unlock it??? Probably not your problem but thought I would mention it.
I forgot once after being distracted during hook up of my Jeep Cherokee. Tires don't like that.
06 Dodge 3500,Dually,CTD,Auto,QC,4X4,Torklifts,Fastguns
2008 Northstar 8.5 Arrow, 100W AM Solar
US Navy 1964-1968, 2-Tour Vietnam Vet
States camped in with Northstar.
Alan_Hepburn
San Jose, Ca, USA
It's actually a common issue with smart cars, and many other cars as well. It's dependent on the geometry of the setup, including distance from the rear axle of the RV to the hitch, length of the hitch receiver, and other factors. The simplest solution is to run a bungee cord from the steering wheel down to the driver's seat bracket. If I recall most people use about a 34" bungee cord - loop it around the bottom of the steering wheel, then connect the ends to the driver's seat frame. The cord allows the wheel to turn for cornering, but pulls the wheel back to center when you straighten up.
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
gotsmart
Aberdeen, WA
Alan_Hepburn wrote: It's actually a common issue with smart cars, and many other cars as well. It's dependent on the geometry of the setup, including distance from the rear axle of the RV to the hitch, length of the hitch receiver, and other factors. The simplest solution is to run a bungee cord from the steering wheel down to the driver's seat bracket. If I recall most people use about a 34" rubber bungee cord (not nylon) - loop it around the bottom of the steering wheel, then connect the ends to the driver's seat frame. The cord allows the wheel to turn for cornering, but pulls the wheel back to center when you straighten up.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
