RV.Net Open Roads Forum: Tow Vehicles: Death wobble, need your ideas
Search only in Tow Vehicles
 > Death wobble, need your ideas
taxgod4u
Bay Area, CA
Posted: 06/11/12 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
follow up on the lift, since it is a 2wd, the lift gets it to the height of a leveled 4x4 + about an inch, no higher, so it is not a monster truck by any means
All things in moderation, except acceleration!
Zip ties, the duct tape of the new milenia!
2001 F250 Powersmoke turbo diesel, 3.73LS
Crew Cab, SRW, SB, 6 inch lift, Single 28 inch semi airhorn underneath! SCMT, A Pillar mounted, Pyro, boost and Trans gauges.
2005 Wildcat 29RLBS, Prodigy, 2 EU2000i's Draw Tite 18K Signature Series, front receiver, on board air, Airlift HD airbags
2003 Ford Explorer XLT 4X4, V8, 5sp AT, 3.73LS
2003 Ford Explorer Eddie Bower 4X4, V8 5sp AT, 3.73LS, Dual semi air horns underneath
2002 XR50, PW50
Denny & Jami
Home Base Nebraska
Posted: 06/11/12 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Had it on my 2WD DRW when in the mountains, took a while to figure it out but it ended up being the brake slide pin not allowing the brakes to retract all so the brakes were not cooling off all the way. When they cooled the warp was gone and every thing was normal again. I also had the same problem after hitting a bump but that was a tire with a broken belt. I would remove the calipers and clean and lube the slide pins.
Denny
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Sumitomo tires
B.O. Plenty
Minnesota
Posted: 06/11/12 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Mile High wrote:
Start with the impacts of the 6" alteration then work down to the factory design.
I agree! This often changes the entire as designed, geometry of the suspension..
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
Dr Quick
M'boro, Tn
Posted: 06/11/12 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
If the problem has happened since you did the lift, then you have your answer. The lift would raise the center of gravity of the truck, and in a turn, that could make the truck want to roll to the outside of the turn.
Dr Quick
Snow_King
Gold Canyon, AZ
Posted: 06/11/12 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
You need more caster! Dodge pickups do this a lot. I dialed in more caster years ago myself. Is this a twin I-beam front end? May take a front end shop and some aftermarket parts to give it more caster. For all of those talking about the lift, it most likely removed caster.
Somewhere in a Fifth Wheel - Where it does not Snow
jjj
Lancaster,Ca.U.S.A.
Posted: 06/11/12 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
I own a 02 ford f-350 super-duty dually. I bought it used with 18000 miles and during a test drive I hit a small bump and had the front wheel wobble on it. It makes the steering wheel wobble back and forth until you slowed down. It turn out that lot of super duties did this if not equipped with a steering stabilizer which mine did not have.The dealer installed one and the problem went away.I would also check the main drag link,it is the rod that goes from the steering box to the right front side of the steering linkage.The joints can wear and be very loose and cause the wobble.I had this problem on my 73 ford f-150 the were so worn out the would just flop around.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
SuperDutyMan
Western PA.
Posted: 06/11/12 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
I've worked on this stuff for years,still have a shop...death wobble,go right to the steering stabalizer,then ball joints,your problem will probably be in that area.
2011 Palomino Sabre 31RETS,5th Wheel,Triple Slide,4000W Onan Genset
2006 Super Duty,XLT, V10, 6 Speed, 4.10, Tow Command, Tow Pkg. 4X4,Dual Exhaust,K&N,Reese 15K,Air Bags
partsjockey
London Ky
Posted: 06/11/12 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Might also look at the track bar. I know from my Jeep days the track bar was a very common cause of death wobble. I was always from the school of thought that said the steering stabilizer didn't actually fix, but merely mask issues such as dw.
1rickw
redwood City, CA USA
Posted: 06/11/12 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Same here... Warped Rotors. Had them turned. All OK now.
2004 Jamboree 26Q + great wife to travel with
kwrightvt
Rustburg, VA
Posted: 06/11/12 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Spoken like a true Jeeper. I'm going to assume Solid Front Axle. Check the entire steering system and make sure you're not running an adjustable track bar with a drop pitman arm. Also make sure the drag link and said track bar are parallel. Steering Stabilizers are very overrated.
The lift kit may be causing it, but there are ways to beat DW and keep the lift.
EDIT: Just did my research, it's IFS. Can't help you there. Only dealt with SFA.
* This post was edited 06/12/12 12:48am by kwrightvt *
2010 Keystone Cougar 322QBS
2006 Silverado 2500HD Duramax Allison Crew Cab 4x4
B&W Turnover Ball/Companion
Prodigy Brake Controller
