Open Roads Forum
Print  |  Close
Topic: Death wobble, need your ideas
Posted By: taxgod4u on 06/11/12 01:58pm
01 F250, 6" lifted 4x2, auto, Crew Cab, Short Bed, 7.3L Diesel, rear air bags, 33" tires 15" rims, teconsia brake controlelr, while towing our 29' 10K lb 5th wheel in the moutains on a freeway, slight down hill, slight gentle left hand turn, new pavement quite smooth, at about 35-40mph in a 45mph zone, gently/moderately applying brakes I got a unjulation in the whole truck. Felt like I had roger rabbit cartoon tundra tires that were flat on the front end, the truck bucked/lunged to the front left wheel which was on the outside of the gentle turn, then rocked back left, and repeated for say 4 seconds back and forth until I got it to say 10mph and pulled over. the steering wheel turned back and forth quite a bit (more than the usual slope), so I had to fight it a bit. pulled over, everything looked good in the suspension and wheel bering areas, checked wheel lug nut torque and they were fine, tire pressure is fine, front pads looked fine. We limped home with no isuses.
I can't figure what failed or went wrong. my only guess is the trailer brakes did not kick in and the rig pushed my truck slightly sideways as we were turned at a 15-25 degree angle to make the turn, kind of rolling the side walls of the tire. any ideas? (let me know if this is too off point and I will move it to the towing forum)
All things in moderation, except acceleration!
Zip ties, the duct tape of the new milenia!
2001 F250 Powersmoke turbo diesel, 3.73LS
Crew Cab, SRW, SB, 6 inch lift, Single 28 inch semi airhorn underneath! SCMT, A Pillar mounted, Pyro, boost and Trans gauges.
2005 Wildcat 29RLBS, Prodigy, 2 EU2000i's Draw Tite 18K Signature Series, front receiver, on board air, Airlift HD airbags
2003 Ford Explorer XLT 4X4, V8, 5sp AT, 3.73LS
2003 Ford Explorer Eddie Bower 4X4, V8 5sp AT, 3.73LS, Dual semi air horns underneath
2002 XR50, PW50
Posted By: donn0128 on 06/11/12 02:34pm
Warped front rotor caused by overheating the brakes. Or loose/worn suspension components. I would take it to a good alignment shop and have them take a serious look at it. If that is OK, then pull the front brake rotors and have them inspected. One or the other is your problem.
Don,Lorri,and Charlie Bear 2016
The Other Dallas
Posted By: copeland343 on 06/11/12 02:43pm
Had that happen several times with our truck. Over size tires will cause (and some times OEM size tires). What it was is a little wear in the steering and the roll bars. Change the shocks and bushing in the roll bar and check the steering stabilizer shock (if you do not have a stabilizer get one it will help as other parts wear). Check tie rods and king pins also. It will get worse as the truck parts wears and gets older. Easy to fix jack up front and change all loose and warn parts. Do not wait it will get worse and may put you in the ditch. You can also Google death wobble on the ford forums and see what other did to fix.
Posted By: zedd on 06/11/12 03:21pm
taxgod4u wrote:
... 6" lifted...
I think this is your problem.
2008 Ford F250 Super Duty, Lariat, 6.4l PSD, Super Cab. Long Bed
2006 Jayco Jay Flight 27.5 RLS Fifth Wheel
Posted By: fly-boy on 06/11/12 02:59pm
Brakes activating on one side of the trailer and not the other.
2016 Chevy LTZ
2009 WW HKD
A few toys...
Posted By: Mile High on 06/11/12 03:10pm
Start with the impacts of the 6" alteration then work down to the factory design.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
Posted By: Don & Linda on 06/11/12 03:43pm
Wow, sounds like a terrifying moment.
This is real tuff one and hard to recheck a fix, without replicating the heart stopping, curved, downhill drive.
I doubt rotors, you would have felt, pulsations in the pedal and warped rotors won't make the whole rig lope and dance.
You checked all the things, I would have looked at, following this event.
You're idea of sidewall fold seems to make the best sense and perhaps compounded fly-boy's idea of uneven brake action adding to the undulations. Slightly worn steering components may also helped start the trouble.(I ran 33s on a 4x4 Blazer and it destroyed stock idler arms like crazy)
Good luck with this one, my heart felt sympathies, as it sounds like you were very close to rolling the rig.
[emoticon] Go with care, Don
Sorry if this post seems long, I lacked the time to make it shorter.
almost quote from S.L. Clemens
Don & Linda
1st RV UL EMS 4s Dome
2nd RV 21' AMF Scamper TT PV D300 Dodge
3rd RV National Seabreeze 133LX w/Demco Dolly
4th RV Jayco 2450 5TH PV Ford F-250 SD
Posted By: sch911 on 06/11/12 03:53pm
Remove the 6" lift and the issue will be gone...
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2007 Jeep Grand Cherokee Limited Toad
Posted By: overthehillbill on 06/11/12 03:42pm
X-2 on front rotors.
Link below is great for answers concerning 7.3's
http://www.ford-trucks.com/forums/forum31/
Bill
'08 Cedar Creek 32TK, 35'9", 13,990#
'01 F-250,Lariat, 7.3L, SC, Auto, LB, JW Towmaster Tranny, 6.0L Tranny cooler, DP custom tunes, 4" Turbo back exhaust, Auto Meter Gauges, Firestone Air Bags. '07 Headlights and Grille, Prodigy P-3.
Posted By: taxgod4u on 06/11/12 04:18pm
thanks all, I don't think the lift is 100% the issue as we have towed for 7 years with it over the same route. Although I am sure it is not completely innocent... I will get the front end looked at soon.
Keep your thoughts a commin' all great input on where to look
Posted By: taxgod4u on 06/11/12 04:19pm
follow up on the lift, since it is a 2wd, the lift gets it to the height of a leveled 4x4 + about an inch, no higher, so it is not a monster truck by any means
Posted By: Denny & Jami on 06/11/12 04:24pm
Had it on my 2WD DRW when in the mountains, took a while to figure it out but it ended up being the brake slide pin not allowing the brakes to retract all so the brakes were not cooling off all the way. When they cooled the warp was gone and every thing was normal again. I also had the same problem after hitting a bump but that was a tire with a broken belt. I would remove the calipers and clean and lube the slide pins.
Denny
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Goodyear G114 Tires
Posted By: B.O. Plenty on 06/11/12 04:31pm
I agree! This often changes the entire as designed, geometry of the suspension..
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Posted By: Dr Quick on 06/11/12 04:38pm
If the problem has happened since you did the lift, then you have your answer. The lift would raise the center of gravity of the truck, and in a turn, that could make the truck want to roll to the outside of the turn.
Dr Quick
Posted By: Snow_King on 06/11/12 04:57pm
You need more caster! Dodge pickups do this a lot. I dialed in more caster years ago myself. Is this a twin I-beam front end? May take a front end shop and some aftermarket parts to give it more caster. For all of those talking about the lift, it most likely removed caster.
Somewhere in a Fifth Wheel - Where it does not Snow
Posted By: jjj on 06/11/12 05:24pm
I own a 02 ford f-350 super-duty dually. I bought it used with 18000 miles and during a test drive I hit a small bump and had the front wheel wobble on it. It makes the steering wheel wobble back and forth until you slowed down. It turn out that lot of super duties did this if not equipped with a steering stabilizer which mine did not have.The dealer installed one and the problem went away.I would also check the main drag link,it is the rod that goes from the steering box to the right front side of the steering linkage.The joints can wear and be very loose and cause the wobble.I had this problem on my 73 ford f-150 the were so worn out the would just flop around.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
Posted By: SuperDutyMan on 06/11/12 06:34pm
I've worked on this stuff for years,still have a shop...death wobble,go right to the steering stabalizer,then ball joints,your problem will probably be in that area.
2011 Palomino Sabre 31RETS,5th Wheel,Triple Slide,4000W Onan Genset
2006 Super Duty,XLT, V10, 6 Speed, 4.10, Tow Command, Tow Pkg. 4X4,Dual Exhaust,K&N,Reese 15K,Air Bags
Posted By: partsjockey on 06/11/12 07:39pm
Might also look at the track bar. I know from my Jeep days the track bar was a very common cause of death wobble. I was always from the school of thought that said the steering stabilizer didn't actually fix, but merely mask issues such as dw.
Posted By: 1rickw on 06/11/12 07:56pm
Same here... Warped Rotors. Had them turned. All OK now.
2004 Jamboree 26Q + great wife to travel with ">
2012 Honda Fit towing 4 down with BrakeBuddy
Posted By: kwrightvt on 06/11/12 09:48pm
Spoken like a true Jeeper. I'm going to assume Solid Front Axle. Check the entire steering system and make sure you're not running an adjustable track bar with a drop pitman arm. Also make sure the drag link and said track bar are parallel. Steering Stabilizers are very overrated.
The lift kit may be causing it, but there are ways to beat DW and keep the lift.
EDIT: Just did my research, it's IFS. Can't help you there. Only dealt with SFA.
* This post was edited 06/12/12 12:48am by kwrightvt *
2010 Keystone Cougar 322QBS
2006 Silverado 2500HD Duramax Allison Crew Cab 4x4
B&W Turnover Ball/Companion
Prodigy Brake Controller
Posted By: Snow_King on 06/11/12 10:32pm
I believe a little Googling says it is a twin I-beam in the 4x2.
Posted By: Mile High on 06/12/12 08:25am
delete
Posted By: partsjockey on 06/12/12 09:25am
Missed the 2wd part! Sorry I'm out there lol
Posted By: Bonefish on 06/12/12 09:38am
The over size tires probably exagerate the effect.
The newer breaking systems have ROTATION SENSORS on the wheels that send information to the ABS or breaking system. If one or more of these go out your truck it will buck like a bronco!
Bonefish
Posted By: Snow_King on 06/12/12 09:39am
More positive caster helps to overcome a front end going into a death wobble.
Caster defined:
To understand caster you need to picture an imaginary line that runs from through the upper ball joint and extends through the lower ball joint. From the side view the imaginary line will tilt forward or backward. The tilting of this imaginary line is defined as caster. Tilting the top of the line to the back is positive caster. Vehicle tracks straighter with more positive caster and steering effort goes up. Chance of death wobble goes down.
Some do not seem to understand death wobble.
http://www.kevinsoffroad.com/how-to-fix-your-own-death-wobble/
Something in this thread to check.
http://www.ford-trucks.com/forums/108601........wobble-w-twin-i-beams-seeking-ideas.html
* This post was edited 06/12/12 09:50am by Snow_King *
Posted By: ol Bombero-JC on 06/12/12 01:54pm
Ditto the above!
"Cyber fixin" - won't cut it - however, try your Q on one of the Ford Diesel forums - lots more folks with lifted trucks there, than here..[emoticon]
Posted By: taxgod4u on 06/12/12 02:59pm
cyber fixin? is that asking others for similar experiences to help identify areas of potential causation, or smashing my PC on the hood...
The diesel folks are coming up with the same scenarios, so everyone is on point! thanks to those who replied so far. I have an apt with a good suspension shop tomorrow and will do the brakes this weekend.
Posted By: Vulcaneer on 06/12/12 06:35pm
I go with steering stabilizer. That's what fixed my death wobble. Get a heavy duty one.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto
2015 DRV 38RSS 'Traditions'
Pullrite Super Glide 18K
Retirement = It's all poops and giggles....UNTIL someone Giggles and Poops.
Posted By: SolidAxleDurango on 06/12/12 06:43pm
LOL if your answer is to go right to the steering stabilizer, I'm surprised you're gainfully employed.
TV = 15 Ram 3500 Dually 6.7 / CC-LB / CTD / Aisin / 3.42 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 "> ) 14 Arctic Cat Wildcat 1000
Posted By: SoCalDesertRider on 06/12/12 07:22pm
How are you fitting 15" wheels on an F250???
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
Posted By: sirdrakejr on 06/12/12 08:28pm
Moved from 5th wheels to tow vehicles.
Frank
Posted By: retired-tech on 06/12/12 09:56pm
if you need a stabilizer to fix a wobble there is another problem. i would get the front end checked out as the death wobble is a common symptom of bad ball joints on a truck that is known for wearing out the ball joints in 2 or 4 wheel drive versions. and the oversize tires arent helping matters up there either.
2014 North Country teardrop in wood
2009 Cougar 320 SRX
Posted By: Turtle n Peeps on 06/12/12 11:02pm
You need to read this.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Posted By: Perrysburg Dodgeboy on 06/13/12 01:37am
I would start by jacking up the truck, putting it on jack stands on the frame. Then grasp the tires at the top and check for up and down movement. The grasp the tires on the sides and check for movement there.
Up and down will be ball joints or hubs, side to side will be suspension (tie rods, drag link or idler arm) or hub. Hint if you have up and down and side to side it's a safe bet you need hubs.
Hope this helps you out.
Don
2015 Ram 1500 Laramie Crew Cab SWB 4X4 Ecodiesel GDE Tune.
Posted By: taxgod4u on 06/13/12 11:29am
could be 16's, I am at work and did not confirm. thanks for the correction. What a difference an inch makes [emoticon] and thanks to MOD for moving this to the correct category. getting some great feed back on where this thing is gonna cost me $. it is never "oh, you just needed more air in your tire, or your tool box shifted..." more like "oh, you need a custom made diamond studded titanium muffler berring"
Posted By: zman-az on 06/13/12 12:30pm
Don
Good advise, however the first thing I would do is have a profesional shop look at your caster angle and do a front end alignment since you did lift this truck. Your problem is most likely due to the lift on the truck, but as mentioned you should be able to make it work fine. I would assume you put larger tires on as well. Not all shops balance these large tires properly so make sure the shop you take it to does a good job at balancing tires. I would also get someone inside the truck and have them turn the wheel side to side in short strokes. Watch all steering componets as well as any suspention parts and links. If you see movment in the bushings of a suspention part that will probably be your problem. I have seen worn out bushings and loose bolts which oval out the frame mounting holes. Your truck has been used so parts wear out, now you throw on a lift with larger tires and these worn out parts are put to more stress and finally showing themselves.
I would not invest in a steering stabilizer as that is only masking a problem.
Keep in mind it may be more than one thing causing your problem.
Posted By: Turtle n Peeps on 06/15/12 11:06am
taxgod4u wrote:
had it checked out, all was fine. BUT the ford stealership FAILED to notice that my pitman arm nut was about to fall off!!!!! I noticed that after they did their thing and I drove it home. Made them beat it to the proepr torque. I added a second nut to act as a jamb nut, painted white lines on it so I can easily tell if if comes loose again. Stupid friking idiots at Ford. Possibly the cause of the original problem, but who knows.
Scary! [emoticon]
Posted By: taxgod4u on 06/15/12 11:01am
Print  |  Close
