RichardFM
Fort Pierce, FL
camperkids1025 wrote: rvten wrote: Did you fill fresh water tank and forget to turn the valve from tank fill to city conn.?
This will cause the pump to run all the time also. Took the words out of my mouth ask how I know.  Jim X3. This is exactly what happens on mine.
2005 Itasca Meridian 34HD
at Fort Mountain, GA
Brian in Michigan
S.E. Mi.
X2
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS, Thorley Headers B&M trans cooler. Auto meter hooked to output of trans. Flowmaster mufflers recurved distributor Still Keepin on Truckin((((Was 7.5mpg Now 8.75mpg ))))
1995brave
San Antonio, TX
I don't understand what water in the freshwater tank has to due with the water pump not turning off. He said he has tried turning the pump off with the switches and it won't turn off. He can only turn the pump off by unplugging power at the pump. To me that's saying the pump controller is bad, or there is a short on one of the switch wires between the switch and the controller. He needs to find the controller and first try unplugging the connector for the switches, if it still runs the controller is bad.
rvten
Crossville,TN
We will never know if the OP does not come back and tell us what he found wrong.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
oldflame
MS
Well after checking the valve going to the fresh water tank is set for city water. There are no leaks around the motor home. Pump run unless I unplug it at the pump. I belive that there is a short somewhere or the presssure switch on the pump is bad.
Lobstah
Northeast
I think if I set my valve for city water, my pump runs non-stop also.
Have you tried changing the valve position?
Jim
2005 Pace Arrow 36D
Very Understanding Wife
2 Boxers
4 Cats
Lobstah
Northeast
And do you have multiple switches for the pump? I have 4, that I know of. One on my main panel behind navigator's seat, one in the 1/2 bath, one beside the bedroom sink, and the last one is in the wetbay.
Are they all off? Mine are push on/push off.
Jim
chili's trip
Full time
Executive wrote: Only two things let your pump run continuously...a worn out pressure valve or a leak in the system. Test your system for leaks usually with air. If it checks ok, replace the pump.....Dennis
or the water tank valve is in the 'fill tank' position! (05 Bounder)
2005 Fleetwood Bounder 32W 8.1.
2009 Honda Fit Sport
RSchleder
iowa city, ia
X2 on valve position!!!!!
oldflame
MS
After checking everything and testing I found two wires were crossed at one of the switches under the kitchen sink. The faucet had been changed out for a new one just before we purchased it. We have not had anymore problems with this pump. Thanks to everyone for the help and suggestions.
