Almot
Vancouver BC
smkettner wrote: pianotuna wrote: Hi,
If I were going to get a battery gauge I'd choose either a Smartgauge or a Victron. But I find a simple volt meter with xx.xx read out meets my needs. +1, I spent the battery monitor money on more battery. Lots more leeway with 4 vs 2 or 1.
Digital voltmeter is sure cheap (I think I saw them for $4), but, correct me if I'm wrong - it only shows Volts, Amps and Ohm. It doesn't show Amp-hours or Watt-hours.
smkettner
Voltmeter just shows volts. You must mean multimeter. Actually I often find my oem four light indicator to be fine to know when to charge. Although some are better than others.
675 watts solar
Raften
Northern Calfornia
Thanks Cedarhill. I have a meter like yours I use for my RC planes so I'll do the same with some RC connectors. I have a TC so access is different than yours but am sure I'll find it easy to do. Mostly interested right now in keeping an eye on a solar system.
crcr
Phoenix, AZ
Trimetric 2025-RV -- I'm about to buy one and install it in our new TT.
pianotuna
Regina, SK, Canada
Hi,
If you must have one get the Victron. It measures more accurately and is cheaper.
crcr wrote: Trimetric 2025-RV -- I'm about to buy one and install it in our new TT.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Almot
Vancouver BC
Yep. $130 Victron 600 doesn't look any worse than $160 Trimetric, and includes shunt. Either one is nicer than Turnigy, and can be mounted wherever you want, far away from battery. Victron can only be mounted flush, if I'm correct.
Raften
Northern Calfornia
Almot wrote: Either one is nicer than Turnigy,
No kidding, the Turnigy wasn't designed or marketed for RV use.
U.P. BLDR
Upper Peninsula of Michigan
I use a Tri-metric, but only because I got it cheap as part of a craigslist score. In the past I've used simple volt and amp meters I bought from Allied Electronics.
1981 Sunline 17 1/2SB - under construction
2003 Toyota Tundra SR5 TRD 4x4 4.7lt
Grub
Pierre
GrumpyGator wrote: After reading a lot of posts in this forum, it seems to me that a good monitoring system would be a plus for my RV batteries.
Has anyone added a monitor and what system can you recommend. I think something with different functions would be a plus.
If you're looking to monitor your engine battery and even possibly your house batteries we just bought one of these little gadgets.
12volt lighter socket battery monitor
You plug it into your lighter socket and it will tell you the voltage.
Any day enjoying the great outdoors beats any day enjoying your 8x8 office cube!
pianotuna
Regina, SK, Canada
Hi Grub,
The volt meter at Walmart is cheaper and does xx.xx so a little better choice I think.
