RV.Net Open Roads Forum: Do I have the wrong wall plate(amplifier) for batwing - pics
 > Do I have the wrong wall plate(amplifier) for batwing - pics
U.P. BLDR
Upper Peninsula of Michigan
Posted: 06/12/12 04:39pm Link  |  Print  |  Notify Moderator
I bought this Sensor IV batwing antenna when redoing my Sunline and later bought the wall plate amplifier not knowing that there's already an amplifier in the head of the antenna. It just hasn't been working right so after a little research and looking at what I have I've learned it isn't the right combo. Can anyone advise which wall plate would go with this antenna?
Here's a shot of the inside of the antenna head, followed by front and back of the wall amplifier I have.
1981 Sunline 17 1/2SB - under construction
2003 Toyota Tundra SR5 TRD 4x4 4.7lt
enblethen
Moses Lake, WA
Posted: 06/12/12 05:09pm Link  |  Print  |  Notify Moderator
The wall plate unit is not an amplifier. It is used to induce 12 volts DC onto the coaxial cable to power the amplifier in the antenna head.
Look at page four of this manual.
Winegard Sensar
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BFL13
Victoria, BC
Posted: 06/12/12 05:18pm Link  |  Print  |  Notify Moderator
The wall plate splitter has one of the stubs with the 12v power (when switched on) Make sure you don't have a Murphy, where the roof coax is on an un-powered stub.
Our trailer had that when new--took me a while to find the problem [emoticon]
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
U.P. BLDR
Posted: 06/12/12 05:33pm Link  |  Print  |  Notify Moderator
Thanks guys, figured it out after doing some research, which I should've done before buying the wall plate amplifier. I need a Winegard RV-0712 or RV-0742 which sends 12v up to the antenna amp.
the_armadillo
SE Texas
Posted: 06/12/12 06:53pm Link  |  Print  |  Notify Moderator
UP Bldr
I would replace your current wall plate with a Winegard Sensar Pro. It will work great with your Sensar IV head. It allows you to fine tune the direction of your antenna by watching the strength readings. Also, if you do get the Sensar Pro, it defaults to a gain of 10. It doesn't state such in the manual, but the gain level can be set all the way to 20 for max gain.
BFL13
Victoria, BC
Posted: 06/12/12 07:00pm Link  |  Print  |  Notify Moderator
Yes, the real PITA is getting stations where aiming the antenna is so critical with digital.
Besides sorting out the amplifier, learn your TV menus for adding channels instead of trial and error searching and hoping for the best. (Where every time you do a new one you lose what you had)
U.P. BLDR
Posted: 06/12/12 07:54pm Link  |  Print  |  Notify Moderator
the_armadillo wrote:
UP Bldr
Hey thanks for the suggestion man! That's a great idea I haven't thought about and will make tuning so much easier. Will be ordering tomorrow.
the_armadillo
SE Texas
Posted: 06/13/12 10:29am Link  |  Print  |  Notify Moderator
UP Bldr
I couldn't tell from your pictures how the screws on your original wall plate mounted in the opening. My Sensar Pro had a template cutout that had two little nubs left in the paneling that I figured would crack as soon as I screwed into them. I used the included backing plate that came with my Sensar Pro and mounted it using some machine screws and lock nuts. The lock nuts were inserted thru the cutout opening. Then I mounted the Pro to the affixed backing plate. Also, You can now get the Sensar Pro in either black or white to best match your decor.
Wherever I happen to park
Posted: 06/13/12 01:24pm Link  |  Print  |  Notify Moderator
A few things.. The wall plate you have is NOT an amplifier, it is the power supply for the one on the roof,, If you disconnect the cable from the roof antenna and hook up either a test lamp or volt meter you should see normal battery voltage at the end of the cable when the unit is turned on.
Second.. There are Sensar 1, II III and IV from what I understand.
1 is unamplified and no longer made
II is amplified, basic batwing
III has the wingman added
IV is an III with a 2nd amplifier (The Winegard Sensar Pro) indoors.
At least that is how I understand it. I may be wrong as I do not work for winegard. Just use the dang thing.
Home is where I park it.
the_armadillo
SE Texas
Posted: 06/13/12 04:00pm Link  |  Print  |  Notify Moderator
The Sensar III was capable of having a Wingman added but did not come standard with it. The Sensar IV has the Wingman already installed.
I don't believe the Sensar IV comes with a Sensar Pro, at least my Sensar IV didn't.
