RV.Net Open Roads Forum: Class A Motorhomes: I need some of these
 > I need some of these
larry cad
ohio
Posted: 06/12/12 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
This is a photo of a "nut" that holds the rear ladder on my son's motorhome. The nut is pushed into the ladder pipe, and then the flange is threaded into the nut and the flange is screwed to the rear of the coach. Some of these "nuts" have rusted out and are no longer useable. Does anyone know what these are called, and where I can get them. The thread is 1/4"-20. Thanks
Our Travel Blog
hershey
Albuquerque,(fulltime) NM, USA
Posted: 06/12/12 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Just finished the same task on my ladder. I purchased some horizontal tubes from Walts RV in CA. They were the wrong ones to fit my installation but I was able to push the spreader nuts (for lack of the correct term) and re-insert them in my application. Then I found a prior forum query and found that that spreader nut is a common item used by bike shops for some application. Just measure your tube and check at a bike shop for the "spreader nuts".
BTW: Let us know what the correct term is
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
dennis and terry
wisconsin
Posted: 06/12/12 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
factoryrvsurplus.com.
also, buy all new bolts; 1/4-20 X 3 inch. i recommend flatheads for the inside ones. rv only has the round heads. hardware store will cover the flatheads. mark all your ladder tubes as my streetsides were 1/2 shorter than the curbside. to get the new ones in the tubes i used a deepwell socket and a hammer. start to finish was 2 hours as i had to dremel the old bolts out. rvsurplus is great to work with and they ship fast.
dennis and terry
2000 damon intruder 349 (The Boo-mobile)
cats Hunter and Jazz
dog Abigail (newly adopted from humane society)
1995 Saturn wagon toad
Go Dogs
South of Pittsburgh, PA
I have not a clue what they are. If it was me, I would take them into my local hardware store. If they don't have it, at least they would either know what it is, or know what you could use instead.
dennis and terry
wisconsin
Posted: 06/12/12 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
they are called "metal barb connectors"
larry cad
ohio
Posted: 06/12/12 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Well, we are going camping in Shipshewana In. next week, so a trip to Elkhart is in order! Thanks for the info.
Dutch_12078
Great Sacandaga Lake, NY
Posted: 06/12/12 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Most bicycle repair shops also carry them, usually under the label "Star Nut".
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
acker1
fulltimer
Posted: 06/12/12 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
X2 on "Star Nuts".
37'--'98 Endeavor
toad--'05 Crewcab GMC
Viet Vet '65, Ia Drang Valley survivor (We Were Soldiers)
Elks
www.4ezdaz.com Same site, different URL
barlow46
Edgewater, FL
Posted: 06/12/12 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
Clicky for FactoryRVsurplus
2005 Monaco Dynasty Diamond IV 42'
04 F450, 6.0 auto, 4:30 rear; BrakeSmart; 50 gal aux.tank, 01 HR Presidential 35CKS, 3 slides, axles flipped; TrailAir Pinbox. pin weight 2760. Total gross TV and 5th: 24,060 lbs.
Executive
Posted: 06/12/12 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
I would go to your local Home Depot and get yourself some rubber nuts. You'll find them in the drawers in the middle of the screw aisle. Easier to use, more secure and watertight......Dennis
Here's what they look like....I used them a lot when building street rods..they come in many different sizes, are not expensive, won't rust and can be removed if necessary......D
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
