zztinker
Central California
I replaced all my lighting with these led's ttp://www.ebay.com/itm/10pcs-12V-Dome-Bulb-36-1210SMD-LED-Warm-White-Adapter-BA9S-T10-Festoon-31-44mm-/170721842426?pt=LH_DefaultDomain_0&hash=
They are brite and warm tone, I am very happy with these.....
2010 Jayco Eagle Super Lite 31.5RLDS Fifth Wheel, 2006 Ford 350 PSD SRW, long Bed, Champion 2000i inverter Generator and a Champion 3500/4000 Gen.
bpounds
Whittier CA
Installed all LED in our last trailer, and pulled them when we upgraded to a fiver. Need a few more now to finish out all the fixtures. I paid about 3 times what they cost now, and that was only about 3 years ago. Prices have come way down. Ebay is your best source, but do your homework.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
bpounds
Whittier CA
ronfisherman wrote: I have replaced all my 921 blubs with LED's off EBAY.
White
Warm White
Are you happy with those? They don't give a lumen spec, but with only 12 LED they are probably not close to a 921 incan.
ronfisherman
SE Michigan
bpounds wrote: ronfisherman wrote: I have replaced all my 921 blubs with LED's off EBAY.
White
Warm White
They are bright. 5050 SMD LED's have 3 LED's in each light.
Kodiak Chassis Class C Forum
Keith M
Cle Elum
Expect to spend $15 to $25 to get a decent led bulb that puts out adequate light and a warm white light . By adequate light I mean 220-300 lumens. A lot of the "white" lights are refered to as "alien autopsy". I have yet to see anyone sell anything on Ebay that meets the qualifications of warm white and 220+lumens for less than $15. The camping world lights are either junk or overpriced or both.
I would not buy a light unless you know the lumens and the seller advertises it as warm white and also shows the current draw. A decent led putting out about 250 lumens will draw about 3.6 watts. Most of the Ebay lights fail to describe either the lumens, draw, or color. A "white" light is an "alien autopsy" light.
majorloser
Central Florida
And a lot of "warm white" LED's are too yellow. I personally prefer to stay closer to "daylight" (5000K) vs. "warm white" (2700K).
http://www.soslightbulbs.com/colortemperaturechart.aspx
http://www.3drender.com/glossary/colortemp.htm
2010 Ram 2500 Megacab Laramie w/Cummins
Firestone R4Tech rear suspension
Pullrite SuperGlide 18K w/ Bedsaver
2012 KZ Durango 1500 D295CS
jgallego
Deer Park, Texas
I changed mine out several years ago. My main reason is that they are so much cooler. The old bulbs gave out a lot of heat.
Jaime
2009 Heartland Big Country 3355
5500 Onan Gold, Ultra Fab Leveling System, Dual Air
TV 2007 Chevrolet 2500HD Crewcab
Duramax/Allison, Prodigy, Firestone Ride Rite
hitec
Lower Alabama
I have the lights that zztinker talked about. They work great. You can figure 7 lumens per light so the 36 light module (7x36)= 252 lumens. That compares very well to the 264 lumens of the #921 incandescent bulb. I think it is plenty bright enough, but the same seller also has a 48 led module.
48 led warm white module
36 led warm white module
terryaGJ
Grand Junction
I've replaced the 921 bulbs with these;
http://www.ebay.com/itm/180754222465?ssPageName=STRK EWNX:IT&_trksid=p3984.m1497.l2649
They are a warm white, 2900-3000K color temperature, less yellow than some of the 3000-3500K color temperature units. They are brighter than the 921 bulbs I replaced (incandescent light output decreases rapidly with age).
And these;
http://www.ebay.com/itm/180776723816?ssPageName=STRK EWNX:IT&_trksid=p3984.m1497.l2649
A nice bright, 6500-7000K light, used in the kitchen and below storage areas.
Don't have a lot of time on them but so far I'm very pleased.
Welfarewagon
Lexington, KY.
I picked up 23 of these on Ebay from this seller, he shipped them fast and they all worked and continue to work to this day.
http://www.ebay.com/itm/906-921-LED-Bulb........ck_Parts_Accessories&hash=item25714fcc06
2006 Sandpiper 325 BHD
2006 Ford F-250 King Ranch V-10
16K Drawtite slider hitch
