RV.Net Open Roads Forum: Tri Glide pin box install issues; move hitch behind axle ?
 > Tri Glide pin box install issues; move hitch behind axle ?
me2
Wherever
Posted: 06/12/12 10:47pm Link  |  Print  |  Notify Moderator
Coachmen Chaparral 355. It has a Lipert 1621 pinbox.
The trailer was stolen, and the pin box got damaged in the process. We recovered it. I bought a Triglide with some of the insurance money. I'm trying to install it.
First thing, the Tri Glide is about 6" longer than the old hitch and about 4 inches higher, from pin plate to mounting bolts.
The trailer rides perfect with the 1621 pin box as it is set right now. When I install the TriGlide, am I going to have to drop my hitch in the truck ? If so, how will I tow a trailer with a regular height pin box ?
I'm hoping that someone has run into this issue and can tell me how they handled things.
Second problem is that I have a hard bed cover on the box of my truck. When I pull the trailer, its folded up at the front of the box. There is about 3 inches of clearance between the edge of the folded lid and the front of the 1621 pin box when hooked to the truck.
The Tri Glide pin box has a much longer pin plate. It extends a few inches further past the pin than does the 1621 plate. Its wider too. On top of that, the shock in the front of the pin box extends even further.
I presently have the hitch in my truck set so that the trailer pin is about 2 inches in front of the rear axle. I could get around the box lid clearance problems if I moved the hitch back a few inches.
How far can one move the hitch back relative to the axle before the truck starts acting squirelly ?
I'm pulling with an F350 SRW LB, CC. 11,500 GVWR, about 8,200 empty. Pin weight is about 2200 lbs.
Thanks
me2
Wherever
Posted: 06/12/12 10:53pm Link  |  Print  |  Notify Moderator
One thing that is bothering me is that the length of my unit is growing daily. And sometimes I pull doubles.
My old truck was a short box. New truck is a long box. Gained 18 inches there.
The TriGlide hitch is about 6 inches longer. We are now up to 24 inches gained.
I probably need to move the hitch back 3 inches. My unit is now 27 inches longer. I can handle the 18 inches going from a short box to a long box, but a 9 inch gain for hitch issues ?
I am very worried about manuverability in tight campgrounds.
The Triglide instructions say to mount it in the same holes as the old hitch. I wish there was a way to mount it 6 inches further back on the trailer. There would be no issue with clearance to do so. But there aren't any bolt holes to allow that to be done.
Ideas ?
Cummins12V98
on the road
Posted: 06/12/12 11:41pm Link  |  Print  |  Notify Moderator
laknox
I agree, it should be a minimum of 2" forward. You should have another set of holes to move another 2"forward. My B&W is full forward ( 4" forward ) and I only add 100# to the front axle with 27,000# combined wt.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
laknox
Arizona
Posted: 06/12/12 11:22pm Link  |  Print  |  Notify Moderator
Thanks
IMO, you don't want to have the king pin behind the axle at all. My B&W puts the centerline of my king pin about 1.5" ahead of the axle, and I wouldn't mind another 1", whatsoever. If you're dead-set on that pin box, I think you'll need to lose the bed cover while towing.
Lyle
1936 John Deere Model A
eHoefler
ozark mountains
Posted: 06/13/12 06:17am Link  |  Print  |  Notify Moderator
If you do move your hitch behind the axle, you will UNLOAD the front axle and have durability and and stability problems.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
byronlj
Arizona
Sounds like you need to lose the tri glide-that solves all your problems.
Dave
byronlj
07.5 Silverado LTZ Ex. Cab 3500HD dually 4X4 duramax LMM/allison 6spd
07 HR Presidential Suite 37RLQ
B.O. Plenty
Minnesota
Posted: 06/13/12 09:11am Link  |  Print  |  Notify Moderator
There are different length Tri-Glides. Call the manufacturer (Lippert) and explain your problem. They can give you the part number for the correct one...Problem solved.
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
me2
Wherever
Posted: 06/13/12 09:38am Link  |  Print  |  Notify Moderator
How do you like your TriGlide, BO ?
According to them, I have the right hitch. Its an L-05, which fits the Lipert 1621 pin box.
Greg 110OVI
SW Ohio
Posted: 06/13/12 10:43am Link  |  Print  |  Notify Moderator
Thought a Demco or Mor/Ryde instead perhaps?
Cummins12V98
on the road
Posted: 06/13/12 10:48am Link  |  Print  |  Notify Moderator
Has ony one done the retro fit to the tri glide? Nine is the L05 long arm single shock.
Any one know what the retro part cost is? And where is a good place to buy?
Thanks
