Grey Mountain
On the rez somewhere in Indian Country
On a recent camping trip, the alarm started beeping and hasn't stopped since except when I disconnect the power supply. House batteries check good, smoke alarm battery is good. My carbon monoxide detector is hard-wired into 12v, no battery.
Suggestions as to cause and solution?
GM
Discovery 39S Tin Teepee
Honda CR-V Toad
Jeep Cherokee Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
talotto
College Station, TX
Assuming you've turned off your propane tank and aired out the coach, unplugged and reset - likely a bad unit. Replace (I got mine at Camping World, but other places carry them). They should be replaced every 5 years or so, I got 8 out of mine.
2004 Itasca Meridian 36G
2004 HD Heritage Softail
College Station, TX
sdianel
Tampa, FL
our Carbon Monoxide detector did that and it was bad. Had to replace it. We replaced the smoke detector at the same time and got a combo unit at Home Depot. Is the beeping from the LPG or CO2 detector?
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
sharker6
fulltime KY, NC, FL, MA, TN
If it's over three years old it may need to be replaced. They have a short life-span.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
swebber
Brunswick , MD
Ditto all the above...got one and a half years from the LP detector in my first trailer...would sound the alarm in the middle of the night.
I have since unplugged the LP detectors in that and every trailer since, while they are parked at home, in hopes that this prolongs their lifespan. So that I do not forget to power it back up, I leave the breaker panel on the floor with the fuse for the detector lying on the cover.
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
Grey Mountain
Thanks much for the replies. Looks like a replacement is in order. Same thing happened in the Class A gasser I had, but I never thought the unit could be bad.
GM
M GO BLUE
Southgate, MI
Ever thought that it may be beeping for a reason other than above????
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
Grey Mountain
I have very carefully checked for propane leaks. It could also beep for all kinds of ambient vapors; however, if that were the cause, those vapors would soon dissipate.
GM.
ScottG
Bothell Wa.
Look at the LED on the front. Green is good, red is alarm and orn/yellow means it needs replacement.
Scott, Grace and Wesly
H0NDA eu2000i
Wherever I happen to park
Was it a rapid beep, or a constant screech, or beep, long pause, beep, long pause.
Each pattern means something different. (The last one is usually some kind of system error not necessary but including low battery power)
You need the manual to figure out what the beep pattern is telling you.. Save for rapid constant or near constant, that's GET OUT OF HERE.
