RV.Net Open Roads Forum: Trip to weigh scales - a friends Megacab/5er combo
Search only in Tow Vehicles
 > Trip to weigh scales - a friends Megacab/5er combo
Page of 5
kenn209
Virginia
Posted: 06/13/12 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Was in the same boat with my 2006 2500 MegaCab. Was over GVWR just with me in the truck, camper loaded for camping, and hardly any fuel on board. Towed it great, but...
2008 Ford F350 DRW Lariat
2010 Cougar 318SAB
Husky 16K slider hitch,
Reed & Carol
donn0128
Pronounced Ore-gun
45Ricochet wrote:
I suspect the rear ST tires won't last to long.
OH You did have to bring that up again didn't you! Now we're going to get more ST tire bashing.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
ib516
Up here!
Posted: 06/13/12 09:02am Link  |  Quote  |  Print  |  Notify Moderator
45Ricochet wrote:
Funny number's Ian. The Open Range 40'er's must be 12k dry?
It's 11,800# with some of his "stuff" in it, but not fully loaded for a trip by any stretch.
45Ricochet wrote:
Like 4x4 said why are the front axles getting lighter when hitched ?
Just me but I'd let some air out cause that front cap isn't close to being level.
Not sure what suspension his RV has but setting in that position the rear axle is going to be carrying much more weight. I suspect the rear ST tires won't last to long.
I'm not sure why the front axle weight dropped with both of our trucks when hitched up. It is only 150# though, so when measured against the ~4600# weight the front axle regularly carries, that's only a 3% drop.
Like I said, it handled, stopped, started, and accelerated just fine.
On the RV tire issue; my suggestion was to rotate the tires frequently front axle to rear axle to try and keep the wear on them even. 800# more on one axle = 400# more per tire which isn't huge.
Sidenote -- I did notice a hint of "launch shudder" when we left the scale with 10 psi in the bags, and zero shudder when they were aired up to 30 psi.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
ib516
Up here!
Posted: 06/13/12 09:07am Link  |  Quote  |  Print  |  Notify Moderator
info taken from here and added to OP
gmcsmoke
Butler
Posted: 06/13/12 10:20am Link  |  Quote  |  Print  |  Notify Moderator
A few comments:
Who cares about GVW, if he's under axle ratings you're fine.
This shows the right COMBO works, hook up another brand's 40' and you could pop the rear tires with the pin weight.
RAM really needs to up their GVWR's to compete with the other two. If it was a GM he would have been under is vwr.
I can't believe how light all the open range models are.
soling2003
Federal Way, WA
Posted: 06/13/12 10:32am Link  |  Quote  |  Print  |  Notify Moderator
I can't believe it either. My 39ft Grand Junction is almost 4000lbs more and it only has three slides.
GVWR does matter, but mainly for when you have the bed loaded and not towing, but it still is a number the manufacturer states is max for the vehicle. That is exactly why I got rid of my F250 and got a dually, plus the added GCWR.
DW and 2 dogs
2011 Ford F350 Dually LB 4x4 CC 6.7 diesel
2007 Grand Junction 35TMS
Peterson 37(just sold) T-37 R/C Sailboat at home
Lantley
Ellicott City, Maryland
Posted: 06/13/12 10:50am Link  |  Quote  |  Print  |  Notify Moderator
The Open Range models are lighter because they have a cable slide system. They can use a lighter beam because the beam does not have holes in it to accommodate the slide mechanism. Open Range models can be 1000-1500 pounds lighter than typical models the same size.
As far as the combo in question, things are too out of whack to draw a lot of conclusions. Get it level and weight balanced between trailer axles. Load it up for camping and then weigh things again.
Too many issues currently exist for me to declare combo is OK.
Some believe the combo is OK because everything is within axle ratings however we know this does not tell the whole story. The trailer axles are out of whack, and the photo speaks for itself. 1000# over GVW is also an issue for me.
This is a good example of why you need to consider all of the towing parameters and not just the ones that are within spec.
Now that everything has been scaled your friend can work on a fix.
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
45Ricochet
North Idaho
Posted: 06/13/12 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Yeah tell me about it.
Anyway not sure exactly which model he has but it appears the 5 slider versions are all triple axle 42' models. This ONE is only 4 slides and has a dry pin of 1960 lbs. And only 11k dry. Almost 18% ratio which is a pretty small number. It doesn't list the GVWR but assuming it's about 14k he will be looking at a pin weight of 2500 lbs fully loaded.
Have fun and safe travels IB
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/13/12 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
The launch shudder is due to the truck's rear springs being too soft. Instead of solving the lack of rear spring rate problem with air bags, add a leaf or 2 to the main packs. That stiffens up the leaf packs and eliminates the shudder, without having to pump up the bags so the rear of the truck is too high for the trailer. MegaCabs have too weak rear springs in them for that super cushy unloaded ride.
He needs to level that trailer, likely by lifting it at the trailer axles with a subframe built under the trailer frame to space down the spring hangers. With so much weight difference on the front and rear trailer axles, his rear axle trailer brakes are doing all the work. This can result in overheating the brakes on that axle, as well as overloading the tires and possibly broken springs on that axle, in the long term.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
45Ricochet
North Idaho
Posted: 06/13/12 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
You might be right Glenn, but many Rams will encounter launch shudder of some kind. Mine developed it about 3 years ago only when loaded down good. Empty it was fine and it's not a Mega Cab. Most of the time it is caused by the carrier bearing from the change in drive shaft angle. Some guys had pretty good luck shimming them, some not so much.
THESE shafts usually take care of the problem 100% of the time. IIRC Ram started using them as OEM in 2008 only to revert back to the twin shafts a year or two later.
On edit I see the link is not good any longer, hope the shafts are. Anyway you can also get them through Dodge dealership but the price was a couple of hundred higher.
On second edit lets try this link
LINK again
* This post was edited 06/13/12 02:23pm by 45Ricochet *
Page of 5
