rerod
Iowa
My four carlisle ST235/85R16 tires are 6 years old and although the tread looks good.. The side walls have hairline cracks starting. From what I'm reading about carlisle tires, I better replace them soon
What brand 16 LT tires should I consider for the long run?
1995 E350 6bt/nv4500, 2006 Featherlite 24' surv toyhauler, 2007 DRZ400s well farkled, 1985 Vmax stock, 1985 Vmax custom
donn0128
Pronounced Ore-gun
Michelin XPS Rib or BF Goodrich Commercial TA would both be excellent choices.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Wills250psd
walnutcove NC
Firestone transforce HT. They work good on TV and RV
rerod
Iowa
donn0128 wrote: Michelin XPS Rib or BF Goodrich Commercial TA would both be excellent choices.
Thanks.. Since my TH spends most of its time in the back yard I'm leaning toward the BF Goodrich Commercial TA for $100 less than the Rib.
Be nice to find them sold on rims..
Slated4Greatness
Phoenix Arizona
Also look at the Bridgestone R250. Incredible steel carcass tire (Like the Ribs) at $100 less.
2004 WW SLC3505
Flipped axles & Michelin LTX's on 16's.
2006 F350 Tow Boss W/Training wheels
ARP's, Decked blk and heads, BPD EGR & WPmp, Snow MPG Max H20, Strictly RR & Aux Cool lines, 4.30:1 gears, SCT W/ID Tunes, FS bags, 6" Aus Stacks, Train Horns.
donn0128
Pronounced Ore-gun
You might also look at Hankook Dynapro AS tires. Those that are using them like them a lot and the prices are generally pretty good.
C.B.
APPLETON WI USA
Ditto Michelen XPS Ribs
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~
CB Family Fleet
Butch&Barb 13CedarCreek~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 11 Laredo
hallock5
Not to hijack (didn't want to start yet another tire thread), but what considerations need to be made, if any, when switching from St to Lt? We are full-timers averaging 1K mi. per month on 3 Marathons and 1 Carlisle, lucky me , in need of some rubber. (225/75/15 ST right now).
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
rerod
Iowa
donn0128 wrote: You might also look at Hankook Dynapro AS tires. Those that are using them like them a lot and the prices are generally pretty good.
Those do have a nice price. I dont really need the mileage because I dont travel much. But I do want dependable tough tires..
Slated4Greatness wrote: Also look at the Bridgestone R250. Incredible steel carcass tire (Like the Ribs) at $100 less.
Where are you finding prices under $250 per?
allcool
sFL Glamis PHX
I've done a lot of research on this. And gotten lots of great forum recommendations/information.
I recommend at a minimum, a commercial grade LT tire, like any of the fleet tires. Its rated specs must fall within the GVWR limits of your th/axles... within reason. My TH had trailer tires with 3500lb rating on my 6000lbs+ (3)axle TH. The TH GVWR is 13,000lb. So my logic is, my TH, even overloaded, will never get over 15,000lbs. Well within the 3042lbs LT tires I have now giving me a 18,252lb total max load tire rating.
Michelin XPS Rib, Bridgestone Duravis m895, Commercial TA, Firestone HT are all fleet type commercial grade tires.
Obviously the Ribs or Duravis are the strongest, being a total steel belt/carcass tire. But their price reflects that. If you have only 2 axles then I would go with the more expensive Ribs/Duravis vs the fiber belt/carcass tires.
I went with the 235/85 16e Commercial TA all season for my 13,000gvw 3 axle th. So far seems like a big upgrade from the trailer china bombs.
What is your 2 axle TH gvw ?
jmo
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
