gijoecam
Midwest
I'm in the midst of a complete brake overhaul on our '04 Jayco 29y. I'm trying to find a good weathertight way to splice the six separate three-wire connections that need to be made. The factory used some special crimp connectors that had a rubber boot over them to seal out water, but even if I could find those, I have no way to crimp them.
I saw some plastic silicone-filled ones yesterday on a new axle, but my trailer parts guy didn't have any and didn't know where to find them... do those work well? If so, any idea where I can find them?
Is the old solder and shrink tube method significantly better?
Thanks, gang!
dupreet
High Point, NC
Solder and shrink is the best. Standard wire splices from Walmart with shrink over them is good too.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
smkettner
What size wire?
I recommend these: They definately have adhesive to fully seal. I would trust them submerged in salt water.
http://www.waytekwire.com
Standard wire crimper and a heat gun needed.
I have these under my truck to connect the extra 7 pin. No issues since 2005 and close to 100,000 miles.
last
edited 06/13/12 10:27pm by smkettner *
View edit history
675 watts solar
SWD
Land of Living Skies
Solder and shrink!
ScottG
Bothell Wa.
Heat shrink, unless it has heat activated adhesive sealant in it, is not water tight and will leak if water is continuously splashing against it. The water tight type is hard to find but can often be purchased at boating supply stores. Don't assume standard shrink has sealant in it.
Scott, Grace and Wesly
H0NDA eu2000i
boogie_4wheel
SLC, Utah
ScottG wrote: Heat shrink, unless it has heat activated adhesive sealant in it, is not water tight and will leak if water is continuously splashing against it. The water tight type is hard to find but can often be purchased at boating supply stores. Don't assume standard shrink has sealant in it.
I ALWAYS squirt some rtv inside the shrink then heat it and squish the rtv out the ends. Now you are water tight and that is exactly what I would do on the trailer brakes.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer, ISSPro Oil and LP pressure gauges in cubby hole, GDP 20/2 filters on frame rail, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
sum1
So-Cal
Liquid electrical tape is also very effective.
opnspaces
San Diego Ca
I have seen sealant filled crimp connectors at both Walmart and Napa auto parts.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Dusty R
Charlotte Michigan 48813
sum1 wrote: Liquid electrical tape is also very effective.
Or, Scotch Coat from 3M. Might have to go to an electrical supply house to find it. It is a very good product for water proofing.
mbopp
Henrietta, NY, USA
I solder, shrink, and use liquid tape.
2013 North Trail 21FBS
2012 F-150 XLT Ecoboost ("EcoBeast") scab
