JKQ
My hitch set up does a very good job & is a good match for my TT & TV. However, it's a pain in the a.. every time I connect & disconnect it's a labor of love, bars, pins, friction bars, put it all away, take it all out. Anybody have a better idea for a hitch & sway set up that is less hastle & works well?
2013 CruiserRv Enterra 314 RES TT, 36ft, 3 slides
2011 GMC 2500 Denali, Diesel/Allison, 4 wheel drive crew cab
Reese WD hitch with dual friction control bars
Dometic 3000 KW portable genset
Kevin O.
Connecticut
I feel your pain and go through the same long drawn out process every trip! And the only thing I could see making it easier is saving money and eventually get a fifth wheel!!
KEVIN
DW-Debbie
DS-Tyler 7yrs old
DD-Makayla 4yrs old
MERIDEN,CT
2011 FORD F150 SUPERCREW FX4 Ecoboost w/Max Tow Pkg and 157" wheelbase
2006 SHAMROCK 21ss(Sold)
2012 Keystone Outback 292BH(New)
skipnchar
Topeka or somewhere else
Equalizer or Reese Duel Cam are both integrated anti sway systems and much easier to use then WD with friction bars.
thiswebs4u
Silverthorne Colorado
Wow, I am glad I didn't have to deal with sway bars. Can you beef up the suspension so no sway bars needed?
Colorado Camping
2001 Dodge 2500 Cummins Diesel
2013 Kodiak 221RBSL
jmiller
S.E. Michigan
One word. HENSLEY.
Joel, Sallie and our lab Jager.(father and son) Chance 9/8/12 RIP
2009 Ford F150 4x4 XLT scab 5.6' Tow Command (NEW 4/09)
2007 Trail Bay TB27RL(NEW 7/09)
Hensley Arrow/Barker VIP 3500/Steadyfast/Dish Tailgater/Maxxis tires/Honda EU2000i
ladywendolyn
Canada
The one suggestion that other people gave us.. Which has helped.. Is to make sure your trailer is very level to the tow vehicle which makes the bars go in a little easier.. And also allows you to leave your unit hitched if you are just stopping for the night.
therink
Rochester
Kevin O. wrote: I feel your pain and go through the same long drawn out process every trip! And the only thing I could see making it easier is saving money and eventually get a fifth wheel!!
X2, one lever, cord and E brake Cable. Fifth wheels are so much easier to hook up and tow. Been there done that. I don't miss it one bit.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
SWD
Land of Living Skies
I've been rving with a TT for the past 7 years. I honestly dont know what the fuss is. I back up, hitch up, connect the plug,chains and break-away, connect the friction anti-sway bars (I have two of them), connect the WD bars and I'm done. Takes me about 10 mins which includes a walk around to make sure nothing is left behind. If I cant get the WD bars as tight as I want I drive to the nearest parking lot and re-adjust there.
ls1mike
Bremerton
I went from a 5th wheel to a TT. I can empathize, but I didn't find it to be to difficult, infact I went from a 25 foot 5 er to a 34 foot TT and they tow about the same, because they are 600 lbs apart. I do get some porpising but it is really not that bad.
Mike
2002 Silverado 2500 HD 6.0 Crew Cab long bed
2012 Passport 3220 BHWE
Me, the Wife, two little ones and two dogs.
Wills250psd
walnutcove NC
jmiller wrote: One word. HENSLEY. X2 simply the best hitch on the market.
