RV.Net Open Roads Forum: Info needed about barker "blue boy" or thetford "smart tote"
 > Info needed about barker "blue boy" or thetford "smart tote"
Page of 5
thomasmnile
Deltona, Fl.
Posted: 06/15/12 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Our Place wrote:
Just curious, why not dump your black tank in the tote? I thought thats what they was designed for however a few people have said not to. Thats exactly why we want it to dump all 3 tanks. I know i'll have to make several trips but that ok with the golf cart.
Absolutely no reason not to dump the "honey" tank into a tote. When I use ours, it's black tank first then the gray tanks to give it a rinse. When we return home, I fill it with a bleach/water solution let it sit 15 minutes, dump, flush, and dry. No hideous odor, no debris in the tank, no problems. Also, my Barker has a short section of hose w/ female couplings on both ends so I connect the tote to a flush hose if the dump station has one.
tvfrfireman
Portland, Or
Posted: 06/15/12 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
Each of my holding tanks is 40 gallons so I got the 42 gallon blue boy. The hose that came with it was so cheap that the first time I used it it resemled a soaker hose. The next thing I did was replace the plastic front and hard rubber rear tires with tube tires. It was inexpensive and easy. It is now a joy to use. I think Barker should give the purchaser a choice to have a decent hose and good tires.
rode2nowhere
southern indiana
Posted: 06/16/12 04:43am Link  |  Quote  |  Print  |  Notify Moderator
I did not get barker due to costs,. thetford was cheaper, have not used yet but i know i will, my wife fills tanks up pretty quick
WeBeFulltimers
Here & There
Posted: 06/16/12 05:41am Link  |  Quote  |  Print  |  Notify Moderator
A JOY to use?!
2007 DODGE RAM 2500 4x4 QC CTD 5.9 4SPD AUTO TIMBRENS PRODIGY REESE 16K KWIK-SLIDE***PACBRAKE PRXB 2012 MONTANA 3585SA
sljkansas
Miami Co. Kansas
Posted: 06/16/12 06:16am Link  |  Quote  |  Print  |  Notify Moderator
I also have changed the wheels on my 42 gallon tank. I have gorilla tires on the front and pneumatic tires on the back. the originals made it the first year, but considering I'm parked for 6 months at one time w/o sewer hookup, I probably use mine more than most do in 3 years. I agree the hose that came with it was cheap, but so are the ones they give you in the starter box when you by a new unit
Yes the Thedford is cheaper but you get what you pay for.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter can now be called a Teacher.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
45 ACP
Posted: 06/16/12 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
I'm another 42 gallon Barker "Blue Boy" user. I too replaced the tires with pneumatics all around. After using it one time with the factory plastic wheels, I concluded the pneumatic conversion was $30 well spent.
I checked out the Thetford before buying the Barker from Amazon. I didn't like what I saw on the Thetford right out of the box. I also didn't like how a local camp host's Thetford had "aged" after regular weekly use.
I tossed the el-cheapo hose provided by Barker and use a 5 foot Rhino extension hose with a changed out female bayonet fitting on the "output" end. (I kept the male bayonet fitting and switch them out so I can use the extension hose for what it was designed for)
I then use my "regular" Rhino hose at the dump station. I don't think it's worth saving a few bucks only to have leakage problems.
2012 Ford F-350 6.7L 4x4 Lariat CC DRW
2011 Blue Ridge 3025RL
2oldman
Winchester WA
Posted: 06/16/12 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Big, small.. doesn't matter for poop capacity, but you need to figure out where you're going to carry/store it to determine the size.
Some people won't put poop in the totes, some won't even poop in their own toilets. Makes no sense to me but it's their trailer.
rode2nowhere
southern indiana
Posted: 06/17/12 04:42am Link  |  Quote  |  Print  |  Notify Moderator
I mounted a modified hand truck to my rear bumper and strap mine there.
restlesswind
Fulltime
Posted: 06/17/12 10:16am Link  |  Quote  |  Print  |  Notify Moderator
"Yes the Thedford is cheaper but you get what you pay for. "
Agree!
I wish I had bought the Barker!
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
rode2nowhere
southern indiana
Posted: 06/17/12 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Agreed! Wish I bought a barker.
Page of 5
