RV.Net Open Roads Forum: Travel Trailers: Can my truck haul this trailer?
 > Can my truck haul this trailer?
NRALIFR
Truck Camping Out West
Posted: 06/15/12 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
And, just to get the terminology right............
Trailers are "towed".
Truck campers are "hauled".
You gotta learn this stuff if you expect to pass the Senior Member test.
2001 Lance 1121 on a 2010 F450
Wildkids
Northwest
Posted: 06/16/12 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
I can see your point but in the same token....Long haul truckers dont call themselves long 'tow' truckers!!!! Just had to make some fun!!!!
Thanks for the schooling!
ewt1163
md
Posted: 06/17/12 08:50am Link  |  Quote  |  Print  |  Notify Moderator
hello everyone from looking at these post i think i should be ok with my half ton pu towing a 29' TT 5800 lbs towing with a 2011 ram quad cab 4x4 with the hemi.
lanerd
Newport, OR
Posted: 06/17/12 10:47am Link  |  Quote  |  Print  |  Notify Moderator
As Ron alluded to above... your payload capacity is the main concern with a 1/2 ton. Once you add the tongue wt of the TT, passengers, tools, equipment, wood, and whatever else you put in the back of the truck, the payload capacity of a 1/2 ton is quickly diminished.
Do your math and be sure ALL capacity ratings are not being exceeded. Most all 1/2 ton PUs have more than sufficient horsepower to pull much more of a trailer than it's rated for. The payload, rear axle, and gross weight of the truck needs to be addressed first.
Hope this helps
Another Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
mehwwh
Posted: 06/18/12 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
To all of you have have this type of Truck, engine, axle ratio, etc. What gear do you tow in?
I have the truck & TT as shown in my sig. and towing in "D" is not an option for me.
I use the Tow/Haul mode and must drive in 3rd Gear. No alterntive.
'03 Silverado 1500, Ext.Cab, Z71 Off Road, 4X4, 5.3L, 3.73 rear, AutoMeter Trans Temp Gauge, Putnam Class IV
'11 Jayco JayFeather Select 242, Reese WD Hitch, HP Dual Cam Sway, 800# Trunnion Bars, Atwood 3500# HD Power Tongue Jack
anaro
Mebane, NC
Posted: 06/18/12 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
oops wrong thread. sorry.
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
6 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
JaredWPhillips
Henryville, IN
I tow in D with the tow/haul mode on if I'm on the highway or flat roads. If I'm on a backroad that's hilly or slow, I'll drop it to "3" to keep it from shifting so often. Also, raising the rpms a bit, going slower and not working the motor or trans so hard gets better MPG.
TV: 2001 Chevy Silverado 1500 ext cab 4x4 5.3 V8. GoodYear Wrangler Authority E-Rated tires, FireStone AirBags.
TT: 2004 Gulfstream Amerilite 21MB
beemerphile1
I'm 57, I'm not a
Posted: 06/19/12 06:26am Link  |  Quote  |  Print  |  Notify Moderator
Wildkids wrote:
...I'm a total newbie to this forum and travel trailers so please bare with me...
No thanks, this is a family friendly forum so please keep your clothes on!
If you keep from loading heavy you should be okay.
Even if you are on the right track, you'll get run over if you just sit there.
- Will Rogers, American actor
Hillbilly Camper
North Carolina
Posted: 06/29/12 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
We tow our camper in D at all times. We just don't "gas on it!' when going up mountains (for example). We just take it easy, no sense in revving the motor up for no reason to get somewhere 5 minutes quicker overall. We tow with a 2000 F150, and our camper is about 4400 lbs. Plenty of motor, and tranny, no sense to waste the additional gas by dropping down to a lower gear..... unless we are going DOWNhill, then sometimes (like Old Fort Mtn.) we will shift down to 2nd and let the truck hold back the camper and save the brakes...
2012 Coachmen Apex - 25 Footer
dodge guy
Bartlett IL
Posted: 06/30/12 05:16am Link  |  Quote  |  Print  |  Notify Moderator
I always recomend taking the dry weight and adding approx. 1200lbs to it. this will get you close to your ready to travel weight! so around 6200lbs give or take, will be your ready to travel weight. shouldn`t be a problem for your truck. I used to have a 1/2 ton Dodge conv. van with the 5.9L and 3.90 gears and towed a 28ft. 6500lb loaded TT with it, it never had any issue doing it anywhere! keep in mind you will feel the truck working hard, but that`s because you will essentially be hauling a house behind you.
You`ll be OK!
As far a sway control systems. I highly recomend the Reese Dual Cam (Staright Line) system! they are the very best WD hitch with integrated sway control! I use it with my 32foot 9200lb TT and it does an exceptional job! just don`t let the dealer set it up, they will never get it right, ask any one here!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
