RV.Net Open Roads Forum: Fifth-Wheels: New hitch question
 > New hitch question
dieseldan723
Pacific NW
Posted: 06/14/12 11:23pm Link  |  Print  |  Notify Moderator
I just purchased a Reese Pro Series 15K hitch. I have always used a Pullrite hitch that required no grease (used a dry lube). I really don't want to grease the hitch and was looking at the lube plate available at my local CW. Can I use this and NOT use any grease?
Thanks in advance!
2012 Dutchmen Komfort 3530 FBH towed by 2008 Chevy 3500 LTZ Dually
2006 Forest River Cardinal 33TBH (sold)towed by 2003 GMC 2500HD (sold)
Prodigy brake controller
dieseldan723
Pacific NW
Posted: 06/14/12 11:30pm Link  |  Print  |  Notify Moderator
Please disregard. I found a recent post stating that most do not use grease. I will probably use my dry lube on the pin but that's it.
kwrightvt
Rustburg, VA
Posted: 06/15/12 01:12am Link  |  Print  |  Notify Moderator
We use some white lithium on the jaws of the hitch and pin as well as the plate.
2010 Keystone Cougar 322QBS
2006 Silverado 2500HD Duramax Allison Crew Cab 4x4
B&W Turnover Ball/Companion
Prodigy Brake Controller
Splashers3
Oakville, MD
Posted: 06/15/12 03:34am Link  |  Print  |  Notify Moderator
I use the plate, BUT, I use a small amount of white lithium grease on the pin and jaws.
2008 GMC Sierra C/C 2500HD D/A - w/Titan 52Gal tank
Ride Rite Airbags, Trail Air Pin Box, Garmin Nuvi 1450LMT,
Blue Ox Bed Saver, TST Tire Monitor, Yamaha EF2000is,
2009 Cedar Creek Silverback, GII, 32 WRL w/ XPS RIBS
maniac007
South Carolina
Posted: 06/15/12 04:16am Link  |  Print  |  Notify Moderator
X3 Use the plate and a little grease around the kingpin the keep friction down.
02 F350SD 7.3 CC DRW, 06 Cougar 314EFS
joelc
Milford, PA
Posted: 06/15/12 04:50am Link  |  Print  |  Notify Moderator
On the plate use the teflon spacer that is sold at most RV stores. There are two sizes. On the moving parts I usually spray with lithium grease 1X per year.
