norfla71
Middleburg
I'm pulling my TH 330 miles to a new home, and would like to know if it's OK to have the generator running; I want to keep the fridge on.
2008 Ram 3500 SRW
2006 Salem 32SRV
***looking for a better truck this fall***
sch911
Rochester Hills, MI
It's ok but that's what LP gas is for...
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
Golden_HVAC
Fulltime, CA, USA
Hi,
Normally people turn on the LP gas, change the refrigerator over to gas, and leave it run that way.
The 8-10 amps that the trailer power cord can transfer to the battery from your toy vehicle each hour usually is enough to keep the battery full, and run the 12 volt controls in the RV.
If you plan on doing a lot of dry camping (without hookups) I might suggest improving the wire size between the tow vehicle and the trailer, then the battery can charge much better and faster. Or install a couple of solar panels, and the battery will stay full, even while in storage.
SunElec.com
Fred.
joelc
Milford, PA
If you fridge uses propane, that would be the better way to go. Propane is not only less expensive than running the fridge on electric (you will save fuel) but will keep the fridge colder. Unless you are trying to exercise the generator while you drive, it is not a good idea. To exercise the generator you would have to also put on high energy consumable appliances as well.
shawnct450r
Goose Creek SC
There may be those who are able to do this, however I don't/can't. When I have the Genny running and the trailer plugged into the tow vehicle (truck running too), it causes my trucks alternator to not like it in a big way. I believe it has to do with my convertor charging the trailer battery and the truck's alternator trying to do the same thing at the same time. I did it once, and my truck made all sorts of bad-sounding noises. Haven't done it since. I run my fridge on propane, and everything is good. Hope this helps.
04 F250 FX4 Diesel
06 WW LE3305
06 Honda TRX450R (CT Racing)
04 Suzuki LTZ250 (Son's stunt machine)
06 Suzuki LT50
07 Suzuki DRZ400SM
jetboater454
Camping or home
I use our genny when traveling,but mainly for the a/c.We turn it on about and hour or so away from our stop.Plus it gives the genny the exercise it needs.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
pianotuna
Regina, SK, Canada
Hi,
Most often there are no issues with running the generator while traveling.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
thinkpt
Tustin, CA
I do it all the time when its hot to cool it down. No problems.
2006 Chevy 2500 6.6L D/A
2007 WW FS2500, Billet etc
2006 Yamaha Rhino Special edition
2006 Honda Trx450er
2008 KTM 530 EXC R
2006 Honda ex300
2009 Suzuki Kx100
2009 Suzuki kx85
2011 KTM 65sx
Son Ryan, Jake, and Jarett
Y-Guy
Tri-Cities, WA
Yes you can run it while towing. We've done it when our dogs rode in the back so we could run the A/C. We run in now when we drive too. However, as noted you can run the LP for the ridge. But! You need to remember to turn of the fridge if you pull into a gas station. In the right situation with gas fumes and the flame for the fridge you can have an explosion. Not too long ago a story came out about this and the gas attendant was badly burned. Don't just turn off the LP tank as the fridge until will try to relight several times before giving up.
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
fly-boy
Los Angeles, CA
We run the gennie all of the time so the kids don't get too hot back there and can watch tv...
2012 GMC 3500 Denali Duramax 4x4
2009 WW HKD with a big garage
A few toys
