RV.Net Open Roads Forum: Frt.brake calipers freezing up on E450 2006 Winni
 > Frt.brake calipers freezing up on E450 2006 Winni
Chief Modo 1941
Home
Posted: 06/15/12 06:55am Link  |  Quote  |  Print  |  Notify Moderator
I have had two right side freeze ups since 2010 and one on dr. side in 2010.Ford does not use s/s or aluminum cylinders in their calipers, as I called and asked. My local shop used calipers made in China which use material called phonic for their cylinders which is not working well, but neither is Ford's either, made in Canada and Mexico using the same type material. I'm sick of Mfs. charging such high pricess for junk made in other countries, especially China. I also don't use a dealership to put the same junk as an independent garage if the parts are the same junk and the independent garage is much, much cheaper on labor. Any input is appreciated especially if you mknow of anywhere I can get calipers with stainless steel cylinders.
Mel
NewsW
US
Posted: 06/15/12 07:38am Link  |  Quote  |  Print  |  Notify Moderator
The best calipers you can get are OEM Ford NEW (Not Reman) calipers.
They cost more, but is available off the shelf from your dealer parts counter.
If you don't ask, they sell you remans.
Go that route and your problems will disappear.
There is a coating on it that ablates over time --- but is not renewed in the reman process.
Twomed
FL winters and then somewhere cool
Posted: 06/15/12 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Those pucks are phenolic a type of plastic...they had problems with heat, swelling sticking. Ask your NAPA guy for rebuilts using stainless. They are available, you need the real NAPA guy, not the kid that looks up stuff on the computer and doesn't know...well you know. Sounds like you have lready BTDT.
Happy Trails
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
ScottG
Bothell Wa.
Posted: 06/15/12 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Stainless is much better than the oem phenolic, we've also BTDT.
Scott, Grace and Wesly
H0NDA eu2000i
carringb
Corvallis, OR
Posted: 06/15/12 11:05am Link  |  Quote  |  Print  |  Notify Moderator
The bigger issue for you is probably the seals drying out from lack of use. E-series rigs rigs, Ambulances which are driven much harder than a motorhome, rarely have sticking caliper issues.
Phenolic pistons are used in almost all new OE brakes, because it doesn't corrode.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
wolfe10
Posted: 06/15/12 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Also important with phenolic pistons to keep the brake fluid changed every 2 years if in a humid climate, 3 if you are in the desert.
Just ask Workhorse about that.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
jeepbluetj
California
Posted: 06/15/12 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Have you replaced the front hoses? They can cause sticking calipers on E-series vans. The failure is that the hose collapses internally, the high pressure from the brake application can apply the brakes, but the collapse basically keeps the pressure in the caliper.
W4MBG
Williamsburg, VA
Posted: 06/15/12 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
last year at the first state inspection for our rv since we owned it, we had to replace the discs (cracked), calipers (sticking, causing the discs to heat up and crack), pads (worn out from pressing against the discs all the time), and front hoses (who knows how hot they got?). also ball joints. 1700 bux! thats more than we paid for the rv!
get it fixed. parts is cheap, life aint!
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
j-d
Sunny Florida USA
Posted: 06/15/12 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
And I'd add - Replace Front Brake Hoses while you're changing calipers.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
trnfla
Tampa
Posted: 06/15/12 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I had to change the brake hoses and calipers with Ford factory calipers 2 weeks ago. It solved my issues.
Please say a Prayer for my 5 year old Granddaughter (Discovered she had Leukemia at 9 months), she has been in remission and tests keep coming back clean.
Now 2004 Winnie Minnie 31C
Had 2007 Zeppelin 190 Hybrid,
1999 30' Dutchman Classic FW
NiceCamps.com
