bikendan
Napa, Cal.
the battery probably has a bad cell. get a hydrometer also.
Dan- Firefighter , Shawn- Musician/Entrepreneur , Zoe- Faithful Golden Retriever , 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
rebel412
michigan
bikendan wrote: the battery probably has a bad cell. get a hydrometer also. Gotcha on the hydrometer. thanks.
Padlin
W. Ma.
Do as you plan and check the battery, if after charging it it shows good with both the hygrometer and the load tester then reenact it in the driveway. If it goes dead again disconnectthe loads via the breaker panel and try again to narrow it down.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
06 Starcraft 18SB
RustyFairmount
Michigan
Where in michigan do you live? I'm in st clair shores. If we're nearby, we can walk through the electrical together. You can also pull the battery and have it tested at pep boys, autozone, etc.
rebel412
michigan
RustyFairmount wrote: Where in michigan do you live? I'm in st clair shores. If we're nearby, we can walk through the electrical together. You can also pull the battery and have it tested at pep boys, autozone, etc. I live in monroe just over the ohio border. I bought a tester and after testing the battery with a load on it, it showed the battery to be bad. I also borrowed another battery and hooked it up and everything works great. So tomorrow I will buy a new battery and install it. A good fathers day project. I really do appreciate the offer though. I'll keep you in mind if I have any more issues. haha.
Jerry9n
SE Michigan
The +/- debate continually comes up. (Ever since Ben Franklin decided on positive and negative). The long and short of it is that it doesn't really matter which you disconnect, either plus or minus, as long as you go back to the battery and disconnect ALL WIRES going to the battery post, either positive or negative.
Bear in mind if you do put one of these switches in and have it turned off, if you forget to turn it back on you probably will not have your emergency breakaway switch working the brakes. Make sure you turn it back on before you tow.
On one other forum, someone posted three wiring diagrams, switch in positive, switch in negative, and a third with the switch in the positive switching everything but the breakaway switch. Unfortunately I couldn't find the thread.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Primus IQ
HTT Mods
RustyFairmount
Michigan
I saw a Roo 23ss at RV show with the cutoff switch inside the camper by the conveter. I asked the dealer why it was there rather than outside by the battery. His answer: To cutoff the camper from the battery without disconecting the emergency brakes or the TV from the battery. I thought that was pretty clever.
Jerry9n
SE Michigan
Found the link with the wiring diagrams. Check out the third.
Thread on battery switches clicky
Chuck_S
Broadview Hts, OH, USA
I've yet to see a trailer completely disconnect and need the breakaway switch. I'll take a chance about leaving the switch off. I'm as likely to forget to couple the trailer.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
