Gene&Ginny
North Kingstown, RI
I could be wrong but I think it has been a year since a nitrogen in tire thread.
hmmmm ..... that reminds me, it must be time to change from winter air to summer air in my tires.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
ol Bombero-JC
christopherglenn wrote: "I got busted for putting green caps on my valve stems with just air in the tires."
-chris
There ya have it . . .The NITROGEN POLICE are out there!!..
SJones37
Upstate NY
Well my new TT came with nitrogen and green caps.Will i keep useing nitrogen in the future if i need to add air to a tire?,i doubt it.
2010 1500 Silverado Z71
2013 Forest River Cherokee 245Q
WindsorJ
Brandon, Miss
SCAM!!!
D & M
Laurel, MD
Waste of money. You aren't racing NASCAR
Dave
Mary, the world's best wife (1951-2009) R.I.P
Lizzy (the Boston)
Izzy & BuddyP - Gone but not forgotten
2005 Itasca Suncruiser 35A
Talk is cheap because supply exceeds demand
CopanoCruisin
The Great State of Texas
My experience in the last year ab
Nd one half is that with the N2', you do not have to add any pressure"............
alaskan-rver
Anchorage, AK
Hope2BRVn wrote: how about helium ? will I get better wear if only the least amount of rubber is coming in contact with the road ?
Another advantage of helium in the tires is that when it can warn you of a leak...my making your exhaust sound like Donald Duck!
Seriously, though, the advantage of compressed nitrogen is that it is readily available, and the process of separating the nitrogen out of the air results in you having a really dry gas.
az99
Pa.
BigBoy11 wrote: My personal experience with nitrogen in my tires is nothing but positive. Purchased new tires at Costco; they put in nitrogen and no, Costco doesn't rip folks off. In over 3 years, never once had to add air which I check monthly. My new Kodiak came with nitrogen from the factory! So far, have not had to add air in almost a year. Run what you want and ignore the skeptics. So you are saying that nitrogen in tires is a magical anti leak gas? If I put it in a tire that leaks air, will it stop the leak?
Bit Bucket
Brookings, Oregon
az99 wrote: BigBoy11 wrote: My personal experience with nitrogen in my tires is nothing but positive. Purchased new tires at Costco; they put in nitrogen and no, Costco doesn't rip folks off. In over 3 years, never once had to add air which I check monthly. My new Kodiak came with nitrogen from the factory! So far, have not had to add air in almost a year. Run what you want and ignore the skeptics. So you are saying that nitrogen in tires is a magical anti leak gas? If I put it in a tire that leaks air, will it stop the leak?
...um, actually yes it will. The nitrogen is a centrifigally based gas. It tends to cling about a central point (like our tire rims) and is therefore much less apt to escape through a leak which would almost always be in the tire tread, which is opposite the rim where the gas clings to.
Complete scientific study on the effects of Nitrogen use in tires.
Camper JamesB
Wichita
Bit Bucket wrote: az99 wrote: BigBoy11 wrote: My personal experience with nitrogen in my tires is nothing but positive. Purchased new tires at Costco; they put in nitrogen and no, Costco doesn't rip folks off. In over 3 years, never once had to add air which I check monthly. My new Kodiak came with nitrogen from the factory! So far, have not had to add air in almost a year. Run what you want and ignore the skeptics. So you are saying that nitrogen in tires is a magical anti leak gas? If I put it in a tire that leaks air, will it stop the leak?
