tileman
Just got back from our 1st trip today. All was good but I did notice that the two air vents in the garage had cold air coming out of them.
I would like to stop the air from coming out because we use the garage for our dirt bikes and the doors are left open in the garage 3/4 of the day. So all that cold air is just being wasted.
How or what do I need to buy to stop the air from coming out these vents. The trailer is a 5th wheel fuzion 310 2012.
The vents are round about maybe 6" or so and there is no way to close them off you can only turn them to make the air go into diff places.
Thanks Ron.
Old-Biscuit
Across the USA
AC Ceiling Vents
I think three of the designs might work......they close off
#5840, #8840 & possibly #8850
Cheap fix.........pull vent, cut piece of plastic/wood to fit inside, reinstall.....air flow is blocked.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
dupreet
High Point, NC
Cheaper fix...pull vent, wrap in Saran Wrap, pop back in place! :-)
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
NanciL
Bakersville, NC, USA
Duct Tape- the silver stuff made for ducts
Jack L
Jack & Nanci
dupreet
High Point, NC
NanciL wrote: Duct Tape- the silver stuff made for ducts
Jack L
With or without a duck?
mlts22
Austin, Texas
The duct vents might be like the ones in my TT -- they do not have four screws, and seem to be snapped/pressed in. They rotate, but do not close. Unfortunately, I can't find a picture on the Internet to show what they look like.
I'd probably see if they can be pulled out without any damage, then follow an above suggestion and put a Saran Wrap covered round piece of cardboard right behind the vent cover.
Caveat: In some TTs, blocking a vent might keep enough CFM of air from going through the A/C that that the compressor or coils might freeze up.
tileman
mlts22 wrote: The duct vents might be like the ones in my TT -- they do not have four screws, and seem to be snapped/pressed in. They rotate, but do not close. Unfortunately, I can't find a picture on the Internet to show what they look like.
Yea mine are like a snap in kind.
If I do block them off there are still 6 more vents that air can come from. And maybe blocking them off will save the cold air for the inside of the trailer.
dodge guy
Bartlett IL
Even easier, turn off the A/C!!! problem is really solved!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
mlts22
Austin, Texas
If they are the snap-in kind, I'd probably go with the no-residue duct tape, or a heavy masking tape. Ugly as sin, but does the job, and if done right won't leave******on the vent.
Wherever I happen to park
A lot dpends on the type of vent but a couple pieces of cardboard (NO NOT the corrgrated stuff they make shipping cartons out of ,, The thick paper they make business cards out of) woudl be mysuggestion
or you could cut a piece of paneling (Wood or plastic) to the size and shape and screw it down over the vent.
Duct Tape, was also my first thought, but in truth, don't work all that well for this job.
My Class A has round ceiling vents for the A/C.. What I would use is most likely a piece of glass-epoxy printed circuit board, cut in a circle with two or three holes dirlled equidistant around the outer edge and a old fashion canning ring (big rubber ring) and screw it up.
The Glass-epoxy circuit board is .. Well,,, Overkill.
