lincster wrote: Pin weight won't go down if water tanks are in front of the axles. I don't care how much weigh in toys you put in the trailer.
My sandrail weighs 2700lbs and the entire rear cage/engine/tranny hang behind the rear axle on my toyhauler. With 150 gallons of water, my pin weight still goes up from 2600lbs (empty) to 3400lbs (loaded).
It won't go down if you're comparing empty to loaded but if you're comparing toys vs no toys, pin weight WILL go down (and that's what I meant). As I said elsewhere, I don't carry water as it will put me over gross.
what are you going to do when you are pulling down I-5 in the center lane, running the speed limit and run over a screwdriver with your left rear on your loaded to the MAX toyo tires and have an immediate blowout on your truck?? Are you going to be able to control your truck and trailer while you try to get to the shoulder with your family in the truck??? That is the big question...Or the same scenario on a 2 lane road, can you keep from having a headon?? I would buy a dually, I did!!
If I couldn't carry full water, all my toys, gas, food, clothing and still be within all of the ratings on my truck and trailer, I would be changing something.
Kevin wrote: If my math is correct my true payload would be 1,675 (GVWR of 10,000 minus true truck weight of 7580 minus 400 in passengers and 345 in slider hitch weight). It's going to be hard to get any pin weight that will work I guess. But my axle weight rating and tire weight rating is still fine, correct?
Boy, I hate to be continuously negative here, but with your RAWR and stated weights you gave, you would have about 2500 lbs left on your rear axle rate rating prior to adding the pin weight. Would be very close.
As for your GVWR, you would only have about 1675 lbs (same as your payload) left prior to adding the pin weight. Obviously, you would still be over by a considerable amount.
However, I live about 10 miles from Spangler Hills here in Sou Cal that is a huge off road area and I see 2500's pulling TH's of much larger size that you are contemplating. My experience is not with 5th wheel Th's, but with normal TT's. From this experience, I know that payload and RAWR are very important to having a safe and reliable rig.
I realize that loading weight in the rear of the toy hauler will reduce the pin weight. However, every TH I've seen has a large "empty" pin weight to begin with....I guess to off set the weight in the rear when loaded.
Like others have said, I commend you for doing this research beforhand. Not many do and typically suffer the consequences later on.
Good luck to you..
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
lincster wrote: If I couldn't carry full water, all my toys, gas, food, clothing and still be within all of the ratings on my truck and trailer, I would be changing something.
Excellent advise here Kevin.....Keep doing the research and choose wisely, pick a trailer with your brain and not because of the glitz, bells and whistles, and shine. Remember, once you haul a trailer off the lot, it will be yours regardless of well it works for you. Rv lots do not have do overs.
Best of luck with your decision....
Sam
2001.5 Dodge QC2500 coal burner, 6spd,BD brake,a pile of other stuff!
little black box, K&N'd,only smokes a little....
2008 Thor Jazz 2870UK 5er
I just have to throw this out there. I was looking at the big rig weight sticker that i drive everyday. The Gvrw is 52k pounds. Now I have always said the ratings are just numbers and recommondations. So why can the whole weight be 80k pounds. That number is 28k pounds more than the rig can weigh. Now obviously 80k is spread between tractor and trailer. Yes I know these numbers are for a tractor trailer set up. But put it into a smaller scale-say your passenger vehicle. Some might see where Im trying to go with this.
So if your tv/th is over weight by any amount over the gvrw. Whats the differance? Or am I missing something.
My Pics
08 F-250 Lariat 4x4 CC
Wife and 2 Little Boys
I don't think the issue here is what the OP can "haul", it's what he can "carry". Your example is irrelevant. The main issue here is the "pin" weight of the TH....not its GVWR.
The OP's 3/4 ton truck is limited in it's GVWR, RAWR, and its payload capacity of which the TH's pin weight will drastically affect.
KmYoung wrote: what are you going to do when you are pulling down I-5 in the center lane, running the speed limit and run over a screwdriver with your left rear on your loaded to the MAX toyo tires and have an immediate blowout on your truck?? Are you going to be able to control your truck and trailer while you try to get to the shoulder with your family in the truck??? That is the big question...Or the same scenario on a 2 lane road, can you keep from having a headon?? I would buy a dually, I did!!
This statement can be with a 1/2 ton and a small flat bed. Dually has nothing to do with a blow out. Just think if you have a blow out on the inner dual all that extra weight will be put on your outter tire and then that could possibly blow out. Can you pull over safely too?
lanerd wrote: I don't think the issue here is what the OP can "haul", it's what he can "carry". Your example is irrelevant. The main issue here is the "pin" weight of the TH....not its GVWR.
Ron
Haul, carry, load its all the same. Most large th that have large pin weight more than likely will weigh a huge amout as well. If the pin is over more than likely the gross going to be very close. All numbers need to be closely monitered if just 1 is in question. Thats my opinion. But I personally have no problem being over any ratings as long as its a huge percentage.
