rgd123
tallahassee fl
I think that my main concern was and is that If you plug a 30 rv into a
50 box, the higher breaker may not "throw" when something in the rv overloads, resulting in some type of damage. Or that the "wiring" in the 30 amp RV may not be Heavy enough to handle the 50 amp circuitry.
rk911
Wheaton IL
rgd123 wrote: I think that my main concern was and is that If you plug a 30 rv into a
your 30-amp RV will only draw 30-amps before, worst case, the breakers *inside* the RV will trip.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
sharker6
fulltime KY, NC, FL, MA, TN
X2...My TT has a warning sticker that says "Wired for 30amp connection". Check yours and see if you don't have the same sticker at the trailer.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
dupreet
High Point, NC
No worries - the 50->30 adapter only removes the second hot wire that you don't need with a 30A/120V RV. Your camper won't know the difference and your breakers will continue to protect your rig.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
Wherever I happen to park
Precautionary advice:
1: Keep contacts (Blades on plug) clean (NOTE Applies to the RV's cord as well)
2: Dispose of it at any sign of melting plastic on the outlet (NOTE THIS WILL happen in time if you use it, do not worry about it, Just replace it)
3 Don't loose it.
Old-Biscuit
Across the USA
sharker6 wrote: rgd123 wrote: I think that my main concern was and is that If you plug a 30 rv into a
As noted in other posts......your RV main breaker 30A will protect your rigs wiring etc. If you exceed 30A draw the main breaker will trip whether you are plugged into a 50A/100A/200A source.
Your S&B house has a 100A Main breaker but everything downstream of that source is protected by various size breakers....30/20/15A.
Same when you use an adapter and plug into a 50A pedestal for your 30A rig.
Just the reverse if you use an adapter and plug your 30A into a 15A
(or 50A rig into 30A)....the 15A source breaker (or 30A) will trip when exceeded.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Chuck&Gail
In the Colorado Mountains
We have been to a number of CG's where your choices were 50 amp, or 20 amp (which may not run A/C). We've also been to a few where the 30 amp outlet was too damaged to use, but 50 amp outlet was fine.
Carry your adapter!
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
pahl68
Newnan, GA
Question.
If you have 30amp and 50amp hookups but only a 30amp trailer and the 30amp plug has border line power would it be wise to use a 50 to 30amp adapter? In theory that should give you plenty of power correct?
2009 Rockwood 8280SS
2007 GMC Sierra 2500 HD 6.0 Gasser
rgd123
tallahassee fl
WHAT ?????????????/
dupreet
High Point, NC
pahl68 wrote: Question.
"Border line power" - to me this refers to voltage...ie having 110V AC or less at the pedestal. Whether you get this from the 30A outlet, or through a dogbone on the 50A outlet, its probably going to be the same.
As mentioned by Chuck & Gail, if the 30A outlet on the pedestal is worn out, using a dogbone and the 50A outlet can get you a better physical connection.
