RV.Net Open Roads Forum: General RVing Issues: Tire Pressure Monitors
 > Tire Pressure Monitors
1L243
Astoria, Oregon
Posted: 06/16/12 12:36pm Link  |  Print  |  Notify Moderator
Anybody using wireless tire pressure monitors for their trailers? I am thinking it might take several minutes before you know you even got one going flat.
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
Chuck&Gail
In the Colorado Mountains
Posted: 06/16/12 12:53pm Link  |  Print  |  Notify Moderator
Pressure Pro screams at you almost instantly if tire get below setting. Time to alarm is vastly different from just getting a pressure reading.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Ron3rd
Upland, CA USA
Posted: 06/16/12 01:01pm Link  |  Print  |  Notify Moderator
The TST system will warn immediately if there is a rapid loss of air. Otherwise it reports at a regular interval.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
billb1
Fort Erie, Ontario, Canada
Take a look at this one Hawks Head I used it with our 33 ft Jayco with no amplifier and as soon as a trailer tire started to lose air it went off. Saved me from two blowouts in the 3 years I used it.
Went over to the Truck Camper last year but still have the sensors on the truck.
BillB
2000 Dodge Ram Quad Cab 1 Ton Diesel, 4.10 axle w/limited slip, auto trans.
2000 Real Lite Truck Camper
dqdick
Council Grove, KS
Posted: 06/16/12 02:17pm Link  |  Print  |  Notify Moderator
Pressure Pro for us.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
OnaQuest
Old enough to be a
Posted: 06/16/12 03:51pm Link  |  Print  |  Notify Moderator
You can check just how quickly your TPMS will report a loss of air simply be unscrewing one of the sensors from a tire. It should be instantaneous. My PressurePro certainly is.
motorcycle jack
FT all over
Posted: 06/16/12 06:23pm Link  |  Print  |  Notify Moderator
The way TPMS works is by the monitor polling the sending units. If there is a sudden loss of pressure that monitor starts sending an alert signal to the monitor immediately. The monitor will stop polling and publish the alert signal.
John
"Motorcycle Jack"
Life time Good Sam Member
Blog: My RV
5th Wheel Blog
Full timing isn't "always camping". It's a different life style living in an RV.
lanerd
Newport, OR
Posted: 06/16/12 07:06pm Link  |  Print  |  Notify Moderator
Can you inform us "why" you think this?
My pressure pro is set for 10 lbs of air loss before the alarm comes on...from the original setting. Typically however, when the tires warm up, they will increase in pressure, so if the monitor says the tire is 10 lbs low, it really means it could be 20 - 25 lbs low. You just gotta know where the original setting is at.
I, on the other hand, typically will check my PP for pressure on all tires about every 15 minutes or so. If I determine one is losing air, I'll definitely pull over at the next convenient stop and check it out.
If the alarm sounds (lights on monitor also blinks) I will I pull over as quickly as I can...convenient or not.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
1L243
Astoria, Oregon
Posted: 06/16/12 08:01pm Link  |  Print  |  Notify Moderator
I have never had a flat tire on a trailer myself. I have driven up next to people who had a flat on their trailer and they did not even know it...
Gale Hawkins
Murray, KY
Posted: 06/16/12 09:30pm Link  |  Print  |  Notify Moderator
2X
Immediately as in RIGHT NOW!
