RV.Net Open Roads Forum: Tech Issues: 10 gal replacement for 6 gal heater??
 > 10 gal replacement for 6 gal heater??
07PSDCREW
Berlin Ma
Posted: 06/16/12 05:06pm Link  |  Print  |  Notify Moderator
Hey all, Id like to replace my Atwood model GC6AA-9E water heater with a 10 gal unit. Does anyone know if there is one that can be used in the same cutout as my 6 gal? I have roughly 16 inches wide by 12.5 tall. Showers......my wife likes how the water is nice and hot, but it dosent last long, 4-5 min if that. I usually run the elec and gas when she goes in too. Do you guys have no problem with a 6 gal keeping up? Reason I ask is maybe mine isn't working to full potential. Before anyone gives the whole "navy showers thing", it's not an option, at least for her.
Any ideas from someone who maybe fit a 12 or 10 gal in?
Thanks
Leon
2007 Ford F350 6.0 CC SB
Fully bulletproofed/EGR/ARP Studs
Reese 16k round tube slider hitch.
2000 Damon Hornet 2850BH 5er ">
Days camped 2011= 34 2012= 46
mockturtle
AZ
Posted: 06/16/12 05:24pm Link  |  Print  |  Notify Moderator
We have never had a problem with 6 gallons being sufficient. It takes only half an hour to heat up. I guess if you stand in the shower for ten minutes and run the water while you're doing the dishes you might run short. I only turn mine on twice a day, morning and evening.
Bear in mind, too, the added weight of a larger water heater plus the 33+ lbs. of extra weight for additional water. Maybe it wouldn't matter to your rig but it might to mine, since it's in the rear.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
EMD_DRIVER
Gerrardstown, WV
Posted: 06/16/12 06:03pm Link  |  Print  |  Notify Moderator
Perhaps change the shower head to a water saving one. Either that, or get her to not have the hot water flowing so fast. Either way will help the available hot water last longer.
2007 Excel 30RKE fifth wheel
2011 Ford F250 6.7l
pulsar
Lewisville, NC
Posted: 06/16/12 08:07pm Link  |  Print  |  Notify Moderator
Moved from Technology Corner to Tech Issues.
Dutch_12078
Winters south, summers north
Posted: 06/16/12 08:42pm Link  |  Print  |  Notify Moderator
The 10 gallon Atwood water heater is 3 inches taller and 3 inches deeper than the 6 gallon heater. You would need to reframe the opening, assuming you have enough clearance otherwise.
Dutch
2001 GBM Landau 34' Class A
07PSDCREW
Berlin Ma
Posted: 06/16/12 08:55pm Link  |  Print  |  Notify Moderator
That figures.... I don't have room to go taller, but I do have extra depth. The height is hindered by the fact it is in a compartment under a bunk bed. Thank you for that info.
Gale Hawkins
Murray, KY
Posted: 06/16/12 09:16pm Link  |  Print  |  Notify Moderator
I like plug and play and the rebuilding/replumbing would be a show stopper for me being lazy. [emoticon]
mlts22
Austin, Texas
Posted: 06/17/12 01:24am Link  |  Print  |  Notify Moderator
If you don't mind waiting, Atwood should be shipping an on-demand tankless water heater that fits in a six gallon bay. I'd consider going that route once they start shipping.
CardinalRule
Gimli, Manitoba (Summer) Yuma, Arizona (Winter)
Posted: 06/17/12 06:49am Link  |  Print  |  Notify Moderator
Change out to one of these. Saves water and increases efficiency of the shower. We love ours.
Dave
I RV, I Golf - Therefore I Am.
2016 Acura MDX (No More Truck "> )
Perminent on site 05 Cardinal 36TS
Dusty R
Charlotte Michigan 48813
Posted: 06/17/12 07:09am Link  |  Print  |  Notify Moderator
Using a pressure regulator will greatly reduce the amount of water used, thus the less amount of water heated.
We only turn the water heater on when needed. Often times I don't wait for the water heater to turn off before getting in the shower, and the water gets hotter as I'm using it.
Dusty
