Dave n Holly
Lansing IL
I have just had Bigfoot Hydraulic Levelers installed recently on my Class C and it seems when I level with the slides in and then put them out it goes off a bit from level, maybe due to the weight of the slide perhaps
Does anyone put there slides out first and then Level??
Thoughts and Comments Appreciated!
2009 Coachman Freedom Express 31
2009 Ford E450 Super Duty Triton V-10
Quadra Bigfoot Auto Levelers
rvten
Crossville,TN
Slides in. Less chassis twisting. after level and slide out. You can always make adjustment if neded.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
Dave n Holly
Lansing IL
Thx rvten.....I was also concerned with less chassis twist thats why I was always leveling first and then putting the slides out.
CrazyTed
Hoollieville #214
I level manually first with my hydraulic levelers. I make sure that I'm just a hair high on my slide side so when it goes out, it levels out.
CrazyTed
www.CrazyTed.us
Va Bch, VA
2010 Husaberg FX450
2008 Triumph Rocket III
2005 Chevy 2500HD 4X4
2008 CrossRoads CrossTerrain TF36DS (Sold)
2009 Jayco Seneca HD 36MS
lanerd
Newport, OR
Be very careful with answers to this question. Different brands require different procedures. You MUST only go by what your manual says. Anything else, and your warranty may be voided.
Take heed.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
Golden_HVAC
Fulltime, CA, USA
Hi,
Back in 96, before slides where as robust as they are today, I was told to always level the coach, then put out the slides. This is because the slides of that day had to be fairly level before deploying them. It makes sense to follow the same rules.
Sure if you can predict that the slide on the drivers side will lower the coach by 1/8 of a bubble, then leave that side a tiny bit high, and it should pull back to level once the slide is out. Or raise the drivers side a bit if needed once the slide is out.
But to pull into a way off level site, then put out the slide, no not a great idea. You need to get basically level before deploying the slides.
Even with my factory installed bigfoot jacks, I will still pull onto ramps if I am way off level. This is because I sometimes take the challenging sites, sometimes because that is all that is left at 9 pm on a Friday, or that they have the best views, when at the edge of the campground near a cliff! So sometimes I have to bring my front tires or rear tires up on 3 levels of 2X10's, then put the jacks down to get it level. I don't need to worry about a slide, I don't have on.
Fred.
korbe
Northern California
When I level, and if there's going to be a little slop, it goes up towards the slide - never down. And then the slide goes out.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
rgrcpa
Mississippi
We level first thing after driving into the site. This to make sure we are on a fairly level site. We have been known to LEAVE one site and seek another. I always hook the electric first so I can put the slide out. I would hate to put the slide out, find I'm not level, and have to put it back in, disconnect the power cord, pack it in, and then move the rig.
Rick Roberts
RV Part-timer
2002 Jayco Granite Ridge 32'
trickyvic3
Raymond NH.
We've had this discussion many times on here, and the most common answer is level first and then slides out. Alot of rigs will lean just a tad to the sewer side for proper drainage, mine does just a bit.
Vic
Coach-man
lanerd wrote: Be very careful with answers to this question. Different brands require different procedures. You MUST only go by what your manual says. Anything else, and your warranty may be voided.
Take heed.
Ron
Very true! Follow your manufacturers recommendation! Different makers have different opinions on when/how to level! Follow their recommendations!
