RV.Net Open Roads Forum: Tech Issues: C7 Huei pump
 > C7 Huei pump
down home
south
Posted: 06/17/12 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
This has probably been discussed before but I didn't find it.
Our 05 Revolution has a C7.
When it is cold, engine heat on or not
it takes several revolutions to get it to fire. When it fires it is not all cylinders at first.
First start when temps are warm takes quite a bit too.
There is no fuel pressure gauge on the coach.
I wonder if the HUEI? pump might be a problem.
The cold start problem has been around for I don't know how long though.
I add fuel lubricity additive when I can find it.
Will judicious use, of additive, prevent problems with the HUEI pump or do I need to plan on replacement anyway?
Anyone else having the cold start issue?
siggyd777
Northern Illinois
Posted: 06/17/12 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
I used to have an 05 Newmar Kountry Star with the 330 CAT with the
HUEI pump.
Let say it was 40 degree F.,turn the key and wait for the WAIT light to go OFF,now crank the engine and she should run within about 3seconds. Whenever it was less then 40F,I would use the engine block
heater for 2~4 hours and the engine would start with NO WAIT light within 3 seconds.
Keep in mind that your air intake heater has to function correctly and also with the HUEI pump the oil pressure has to come up to a certain level before the injectors are fired.
When it is cold,use the engine block heater! it warms up the oil,you need less current for your starter motor and it is less drain on your
batteries.
Hope this helps.
Siggy D.
* This post was edited 06/17/12 08:30pm by siggyd777 *
Happy Trails
Siggy & Ursula
2011 Dutch Star 4020,ISL 400,Compr.brake,FTL XCR,IFS
Allison MH3000
2005 Saturn VUE AWD V6 , Brake Buddy,Roadmaster Sterling,
Camping since 1975 Pop-Up,1986 22Ft.TT,1999 Gas MH,2005 KSDP,
2011 DSDP,FMCA 368283 , NKK 17385
Big Katuna
Deland, FL
Posted: 06/18/12 05:33am Link  |  Quote  |  Print  |  Notify Moderator
Batteries good? Mine (C7) started cranking longer and I realized my batteries were five years old. Replaced them and it hit off much faster. Would explain the missing though. Have you had Freightliner check the codes?
My Kharma ran over my Dogma.
wolfe10
Posted: 06/18/12 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Very difficult for us to diagnose over the internet.
Could be as simple as the relay or fuse powering the intake manifold heater is inoperative.
I would take it to a Caterpillar dealer for diagnosis. And, were it a Cummins, would suggest taking it to them.
And, neither Caterpillar nor Cummins endorse the use of any fuel additives. Said another way, all their engines are designed to run on ULSD.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
Jim-Linda
Livingston, TX
Posted: 06/18/12 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Agree, head for a Cat service shop. Recently had to have one injector repaired for similar problem.
Jim
 > C7 Huei pump
