RV.Net Open Roads Forum: Dash air quit spittin' out cold air today mobile tech?UPDATE
 > Dash air quit spittin' out cold air today mobile tech?UPDATE
wolfe10
Posted: 06/18/12 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Anyone competent to work on automobile A/C can work on you dash HVAC.
They use the same components and refrigerant.
I am with the "get it fixed now" group, as something as simple as a blown hose could allow moisture in that would cause a lot of other problems if left unattended.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
klm
SIOUX FALLS, SD
Posted: 06/18/12 07:03am Link  |  Quote  |  Print  |  Notify Moderator
OP back again. I will be near a freightliner service center - they work on motorhomes - not much else in the area that does rv's - do you think freightliner might be able to do this repair? And yes, I will keep the ac off - thanks again, guys. I actually appreciate the variety of answers - it shows me that the problem will take some effort to get it properly diagnosed.
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
bdpreece
Woodburn Oregon
Posted: 06/18/12 07:18am Link  |  Quote  |  Print  |  Notify Moderator
SNIP
Brett;
Don't count on that. Then again you did say can rather than will. I just spent over a week traveling from Lake Charles La. to Orlando Fl. During that time I contacted several places including RV repair shops and Freightliner trying to get someone to repair the dash air in my coach. Empire Freightliner who is listed as an Oasis (rv repair) repair shop and has 8 shops across the South said they would service the compressor but nothing else. Others just said they did not want to work on motorhome air conditioning. I finally ended up troubleshooting it myself with the help of others on the internet. I was finally able to find the part at Alliance Coach in Wildwood Fl. So once again we are happy (and cool) campers
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2008 Ford Explorer toad
Wherever I happen to park
Posted: 06/18/12 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
IS it a repair a mobile tech can address: Perhaps (And if not he will know of a shop that can finish the job he starts, saves you a lot of time in the shop).
Second: Where as I do not know your system, Mine has 3 fuses. One just for the blower, One just for the compressor and one for the control electronics.
That last one failed and suddenly nothing worked .
tgobob
Titusville, FL, USA
Posted: 06/18/12 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Getting back to your original question as to whether or not a mobile tech could repair your dash AC, the answer has to be "maybe". All of the above answers are possibilities and depending on what the actual problem turns out to be, he might be able to fix it. I had a problem with my dash AC similar to your symptoms. I was headed to Tiffin in Red Bay, AL so decided to wait til I goth there to get it fixed. The diagnosis turned out to be low freon. However, these days to replenish freonPROPERLY requires some pretty sophisticated equipment, which a mobile tech is unlikely to have. The system has to be completely evacuated by putting a vacuum on it and then refilled. It's rather time consuming and not really very simple. My low freon was caused by a leaking connection which was easily fixed.
tgobob
Titusville, FL
2003 Allegro Bus
350 HP Cummins ISC diesel engine
Freightliner chassis
Age is a state of mind. Think old and you are old. Think young and you're still old.
Tarheel 2
North Carolina
Posted: 06/18/12 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, Freightliner should be able to repair your system, they did my present motorhome and another that I had a problem with the air conditioning 5-6 years ago.
Tarheel
klm
SIOUX FALLS, SD
Posted: 06/19/12 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
OP - a bit of an update. I stopped by the freightliner repair center today (in the toad) and talked to the service manager. I explained the situation with the dash AC. He said to bring it in, they will work on it. I saw several mh's there, a couple in the bays. It is a large, clean facility. I will be there early Monday morning - let's hope they can diagnose the problem and fix it.
bdpreece
Woodburn Oregon
Posted: 06/20/12 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Good luck, sounds like things will work out. We have had great luck with some Freightliner shops and a less than gratifying experience with Empire Freightliner in the South. Spent 4 days at Martin Truck Center in Lake Charles La and could not have been treated better. They even provided overnight parking with 50 amp power.
Let us know how you make out.
tropical36
Southwest Florida_USA
Posted: 06/20/12 08:47am Link  |  Quote  |  Print  |  Notify Moderator
klm wrote:
My dash air stopped sending out cold air today, now it is no cooler than when I put the dial on "vent". Is this a repair a mobile tech can address? I can live w/out, by using genny-roof air, but prefer to get it fixed. I am a fulltimer, currently in transit. The coach is '02 Newmar Kountry Star DP built on a freightliner.
They all go eventually. To each his own on this, but IMO, they were a waste of time weight and money in the first place that could have been put to better use elsewhere.
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal Model 6350 on a 1997 Chevy P32
Chassis_7.4 Vortec Engine_4L80E Tranny_slide_tag axle.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
MrWizard
Traveling
Posted: 06/20/12 09:26am Link  |  Quote  |  Print  |  Notify Moderator
ours is marginal efficiency when working
it barely cools the drivers area, but that's better than burning propane for the onboard Onan
its better if you have a SuperC or whatever they call big house trucks now
you more cooling effect in the cab area with those units
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
