Robby9
Oklahoma City
My camper got totaled due to a hail storm. It was 31' and 6500lbs loaded.
The new TT is 34' and will weigh about 7600lbs loaded. The tow vehicle is a 2011 Chevy 2500hd with the 6.0L and 3.73 rear. Tell me the setup will be fine for my trip to Colorado and that handling the extra three feet of camper is no big deal. Thanks.
jerem0621
Sequatchie, TN
Set up the WD hitch right, and use some sort of sway control.
Don't worry, you look like you are good to go as long as the TV is in good shape..
You will not notice the extra 3 ft traveling down the road.
Thanks!
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Jim Cindy
Northcentral, PA
With your rig, it is all about the hitch. get a quality WD hitch and enjoy your trip.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
Robby9
Oklahoma City
Thanks. I'm hoping to hear some positive feedback from others with similar rigs.
fla-gypsy
North Florida
No worries unless you are the squeamish type going up and down hills.
jerem0621
Sequatchie, TN
Robby9 wrote: Thanks. I'm hoping to hear some positive feedback from others with similar rigs.
I suggest that you go over to the fifth wheel section and look around. There are a TON of 6.0 towers pulling fairly large fivers. Lots and Lots of positive feedback on that gasser.
Thanks!
Jeremiah
kknowlton
southeast Idaho, formerly IL/WI border
Sounds good to me.
therink
Rochester
My tow vehicle specs are in sig below. My fiver scaled is 11,800 loaded. My 6.0 gasser does a great job but does work oh mountain hills. It helps that I have 4:10 axle. As long as you stay below 10k with your 3:73 axle, you will be fine. The engine will work on the hills, but don't be afraid to let it run in the 4,000, rpm range. The engine has its best power in that range.
Steve
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
APT
SE Michigan
First real trip with my 6.0L/6-spd/3.73. Love it! While my loaded weight is about 6500 pounds, it does well. I use tow/haul mode and M5. You should be good with your setup.
2012 VW Passat TDI
Robby9
Oklahoma City
Thank you for your replies. I'm feeling better about the situation.
