SCVJeff
Santa Clarita, CA.
After procrastinating on a cover to keep rain & moist foggy weather out & summer storage venting, I finally bought a MaxAir2 cover for my Fantastic Vent fan, only to find that the Fantastic frame seems to be 1/2" wider than the mounting hardware of the MaxAir2 cover, and it won't fit without some metal work.
I exchanged it for the Fantastic Vent cover only to find out that the only way to mount this one is to cut away the Itasca factory sealant on the roof to attach it's mounts (the MaxAir mounts attach to the vent frame rather than requiring compromising the roof seal), and I ain't gonna do that.
So, question to the floor: Who has a 6000 series Fantastic Vent (I suspect they're all the same size) that has added a cover that didn't require cutting into the roof seal or modifying the mounts??
Jeff - WA6EQU
Golden_HVAC
Fulltime, CA, USA
Hi,
I installed all my fantasitc fans, so cutting away the rubber roof sealant, then replacing it did not bother me at all. I did not have any fantastic fans from the factory.
I put on maxx air vent covers back in 1996, after trying a solar powered vent that covers a roof vent and had it's own fan inside it that was about 12" diameter, but did not move much air, and already having a 165 watt solar system did not need the additional expensive solar panel on the fan that was not effective at moving air in the daytime, and I don't recall if it connected to the battery for nighttime use.
Anyway I am really happy that I installed Maxx air covers, used rubber roof sealant on the brackets, then after that dried about 24 hours bolted on the new Maxx air covers.
My Fantastic fan roof vent covers are still intact, no cracks or UV breakdown, due to the covers protecting them.
Fred.
RvBill3
Collinsville, IL
I used the Fan Mate cover by Maxx Air (specifically for high speed fans like fantastic fan) . It attached to the frame with 4 screws no problem. I love being able to leave the vent open in summer storage and using the fan in all weather conditions.
2012 Forest River Sunseeker 2300 Chevy
dbbls
Missouri
RvBill3 wrote: I used the Fan Mate cover by Maxx Air (specifically for high speed fans like fantastic fan) . It attached to the frame with 4 screws no problem. I love being able to leave the vent open in summer storage and using the fan in all weather conditions. I have the same cover. Did not have to remove any seal because it fastens to the frame.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
pasusan
PA
dbbls wrote: RvBill3 wrote: I used the Fan Mate cover by Maxx Air (specifically for high speed fans like fantastic fan) . It attached to the frame with 4 screws no problem. I love being able to leave the vent open in summer storage and using the fan in all weather conditions. I have the same cover. Did not have to remove any seal because it fastens to the frame. Same here.
Trip Pics
"Don't let the sound of your own wheels drive you crazy." JB & GF
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
Kamphiker
South Florida (this 'aint paradise anymore)
I put a Max cover (the newer style that you pull pins out on one side to lift the cover & clean) on my Winnebago / Fantastic Fan.
What I did was to lay the mounting brackets for the Cover on top of the sealant (and it is a silicone type from Winnebago) mark both sides of the bracket(s), then use a razor/utility knife to remove the sealant between the lines so the brackets would lay flush.
after everything was aligned & tightened down sealed over the brackets with RTV silicone.
Winnebago uses a self leveling silicone unlike any you can purchase in any local warehouse / store.
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
Ivylog
Blairsville, Ga. USA
I used silicone to glue mine on and that was 40,000 miles ago.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
JC2
Mo
SCVJeff wrote: After procrastinating on a cover to keep rain & moist foggy weather out & summer storage venting, I finally bought a MaxAir2 cover for my Fantastic Vent fan, only to find that the Fantastic frame seems to be 1/2" wider than the mounting hardware of the MaxAir2 cover, and it won't fit without some metal work.
Hopefully what you got is returnable. These are the covers that we're going to buy for our Fantastic Fans.
http://www.rvupgradestore.com/SearchResu........reeze+Vent+Cover&Submit.x=53&Submit.y=15
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
IAMICHABOD
Sunny So Cal
pasusan wrote: dbbls wrote: RvBill3 wrote: I used the Fan Mate cover by Maxx Air (specifically for high speed fans like fantastic fan) . It attached to the frame with 4 screws no problem. I love being able to leave the vent open in summer storage and using the fan in all weather conditions. I have the same cover. Did not have to remove any seal because it fastens to the frame. Same here.
Me too it is great and opens and works great.Here is how to install.
maxx air fan mate
No cutting and resealing.
2006 TIOGA 26Q CHEVY 6.0 VORTEC
Recycled El Monte RV Rental
Buying A Rental Class C
SCVJeff
Santa Clarita, CA.
JC2 wrote: SCVJeff wrote: After procrastinating on a cover to keep rain & moist foggy weather out & summer storage venting, I finally bought a MaxAir2 cover for my Fantastic Vent fan, only to find that the Fantastic frame seems to be 1/2" wider than the mounting hardware of the MaxAir2 cover, and it won't fit without some metal work.
http://www.rvupgradestore.com/SearchResu........reeze+Vent+Cover&Submit.x=53&Submit.y=15 Still reading down the thread, but this was the 2nd one that was returned because it requires cutting into the seal which, as mentioned above is like nothing else avaliable, so I'm not gonna break whats not broke.
