RV.Net Open Roads Forum: Toy Haulers: Who's towing a Voltage 3200?
Search only in Toy Haulers
 > Who's towing a Voltage 3200?
mowdoc
Las Vegas!!
Posted: 06/19/12 10:41am Link  |  Quote  |  Print  |  Notify Moderator
I pulled a Fusion FZ310 (almost identical your 3200 Voltage) with a 2011 F250 and 355 axle. You will HAVE to install air bags!! With air bags at 50 - 55 psi the Ford will handle that trailer just fine. Even in Colorado.
What you will find is at the scales. I was 1400 over GVWR pulling my Fuzion so I traded a perfectly good F250 with 19k miles for a new F450. I know that is overkill but I wanted plenty of truck for future work.
You will get 7mpg with your truck and Voltage if lucky. It will pull as good as my F450 does (I can't tell any difference between the trucks as far as power goes) and the F450 has 430 gears. I do notice the F450 has much better brakes and of course, the dually stability.
Your F250 will do a fine job with that Voltage but you need to understand you will need air bags and the tr5uck will be outside it's design limits.
Happy Camping!!
2012 Fusion FZ310 Monster Edition
G614s all tires
2012 F450 Ultimate Lariat
DuraFlap flaps all 4 corners
60 gal aux fuel tank
Reese 18K 5th wheel
BedRug liner
asuperheat
Posted: 06/19/12 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Advrider29 wrote:
Asuperheat,
What gearing would you recommend?
I think the 3.55 gears will pull this trailer fine. The 6.7 makes 800 ft lbs at 1600rpm. I would not change anything with the truck. I think you have enough truck for this trailer. Would 3.73's be better towing? Sure but I dont think you will have a problem with the 3.55's I pull a 3795 with less power and 3.73:1. My trailer weighs in at 19k, pulls fine. As stated above pin weight may be a issue though.
grizzly660fan
Utah
Posted: 06/20/12 11:17am Link  |  Quote  |  Print  |  Notify Moderator
check around, a lot of 3/4 ton and 1 ton trucks have exactly the same running gear and only differ by a single leaf spring in the rear. while the badge may say 3/4 ton in reality it will do a lot more. also check the tire ratings and if necessary add air bags as others have suggested.
you can also do other upgrades to the truck that are a lot cheaper than replacing the truck. for example adding an exhaust brake (pac brake and others) will help a lot when towing any size trailer.
good luck!
2012 Epic Voltage 3905
2003 High Output Dodge Cummins
ljbsvt
THE OC Baby
Posted: 06/23/12 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
Tires should be fine, Ford puts E rated on their Super Duty's
Airbags will make the ride much nicer, I've had them on all my F-250's.
that gearing with that motor will pull just fine, plenty of power.
2011 F-250 6.7 Lariet CC/SB Loaded
2011 Jeep Wrangler Sport
2007 Gearbox 295FS
Pullrite Superglide
2004 KTM 525 MXC - Mine
2006 Polaris Preditor 500 - Her's
2007 Raptor 700R - Mine
2008 Rhino - ours
Member ASA, CORVA
stsmark
Northern CA
Posted: 06/23/12 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
The 3.55's are matched to the tranny really well. There is no issue.
Mark, Cathy and Zoey (aka The Golden Missle)
2011 F350 CCSB 6.7 (aka Frosty)
2011 Cyclone 2812 (aka The Little Guy)
Lasher Sport ATH
Lasher Sport BTX
Advrider29
San Antonio, TX
Posted: 06/24/12 07:36am Link  |  Quote  |  Print  |  Notify Moderator
I want to thank everyone for helping out. I pulled the trigger yesterday and bought my Voltage 3200. I have also ordered B&W removable hitch and air bags. So hopefully by next weeked I will camping in our new rig.
Ya'lls help was invaluable, so thanks again!
Gerald
San Antonio, TX
TH: 2012 Voltage 3200 EPIC
TV: 2012 F250 KR
2012 KTM 350 XC-F
2008 BMW 1200GS Adv
2008 Husquvarna TE510
2008 Ducati Hypermotard S
2007 Beta Rev3 250
2012 RZR 900XP
2012 Santa Cruz Tallboy C XX
Kids: 2 x Oset Trials, 2012 KTM 50 SX Mini
Wife: 2012 KLX 110
asuperheat
Posted: 06/24/12 09:07am Link  |  Quote  |  Print  |  Notify Moderator
I think you will like the B&W also, I am very happy with mine. Congrats on the 3200.
ljbsvt
THE OC Baby
Posted: 06/24/12 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Nice, always fun to bring home new toys.
you'll find that the airbags help improve the ride quality as well as level out the truck. I normally run mine at 45-55 when pulling, and normally have firewood in the bed of the truck as well.
