want-a-be
Indiana
Was wanting to know what is the best product to install under RV wheels for long stays. Was thinking of 2x12 pressure treated but didn't know if there is something better?
Thanks for any and all comments!
pkunk
Questa, NM
2x12 most likely will crack if on the slightest uneven ground. Best would be treated (green) exterior 3/4" plywood, glued & screwed in a couple of layers and those can be made in a wider & longer set for the rear duals.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
dupreet
High Point, NC
I use 2x6 pieces. If got a couple that are about 3 1/2' long that are pressure treat that normally hit the dirty first. The rest is regular 2x6 stock.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
wolfe10
If all you want is to isolate the tires from the ground, some throw away pieces of 3/8" plywood sized to support the whole tire (front) and both tires (rear) work well.
If you are using these to level, go with Paul's (pkunk's) suggestion, as they would be much less likely to crack.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
JcoFS3500
East Central OK
I built my pads out of 2 layers of 3/4" pressure treated plywood screwed together to make 1-1/2" thick pads. 30"x30" for the rear & 30"x18" for the front. 2 years and still good as when I built them, just dirtier. The reason for going so thick was to keep the coach from sinking in soft ground. Figured that thinner would just crack as the tire sank.
'93 Jayco FS3500 TT behind a '92 Dodge D250 powered by 5.9L Cummins
'94 Vogue Prima Vista powered by 8.3L Cummins w/ 6spd Allison
rvrepairnut
bc
want-a-be wrote: Was wanting to know what is the best product to install under RV wheels for long stays. Was thinking of 2x12 pressure treated but didn't know if there is something better?
2 by 12 is more than adaquite.been usng it for years,I have used it under my jacks also and never had it crack so pretty doubtfull it would crack under the wheel weight on solid ground
fordsooperdooty
Ground moisture is a big cause of damage to long term parked RV's.
Moisture can be trapped inside and between the wood and the tires.
Keep the tires aired up, keep them dry and if possible drive the vehicle on occassion to re-distribute the natural waxes added to the rubber when made.
This prevents aging, cracking, etc. Keep the tires sprayed with 303 Aerospace spray to prevent UV and ozone damage. Covering them also helps.
And use these..they're inert plastic, they are a complete system, including chocks and ramps, keeps Lynxthe tires off the ground, dry and air circulating.
PLUS these guys have supurb customer service!
Lynx
Nomadac
Columbus, IN
The only long term parking I do is in my driveway(concrete and asphalt) or Versa Tube RV Port with gravel. I use 3/4" exterior pressure treated plywood 2 pcs. 24"x24" for rear duals and 12"x24" for frt. wheels I have painted both with ext. porch paint to keep them easier to clean, if needed. They have worked great for me.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
want-a-be
Indiana
Thanks for all the information. I think I will go with the 3/4 pressure treated plywood, less weight and can go 24x24 for rear wheels.
down home
south
What the others said about glued and screwed marine or exterior plywood with paint.
I'm using 2x14 pieces. They work alright until they get wet. I painted them sorta. They split. They are heavy but so is the coach.
The plywood is heavy too but stronger and won't split. Too lazy to get around to makin them yet.
I saw what I needed on a big Electric utility truck. Large and thick plastic with ropes on the end.
Tain't cheap Mcgee.
