RV.Net Open Roads Forum: Beginning RVing: Hot water tank question
 > Hot water tank question
NY
Posted: 06/18/12 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
During our first year in the RV, we used the hot water heater twice in the Fall. During the summer, with the outside temps in the 80s and 90s the water coming out is warm enough. For showers we use the campground and we don't wash dishes in the sink.
As we are starting out this season I had the thought to empty the hot water tank and just keep it in bypass - should we need it in the Fall, I can always put it back on the line.
The hot water heater/tank is a Suburban 6 gallon tank. I first bypassed the hot water tank. I drained the water out as much as would pour out the drain hole and on a suggestion I was given, I hooked up a tube to a wet-vac and got what I thought was all of the water out of the floor of the tank. I left the anode rod out with the drain hole open for a couple of days to let the rest of the moisture evaporate out. Today when I went to put the anode rod back in, the little I could feel inside with my finger through the drain hole there was still some water inside. It looks like there is no way to completely dry out the inside.
Now, am I going to regret doing this because the little water and moisture inside will rust or damage the inside of the tank? This is supposed to be a steel glass lined tank, but there is an anode rod and the rod now will not be in the water at all to protect the tank with the little water that sits below it. I am thinking that the tank would just be better with water in it so that the anode rod does its job and I won't be causing a new problem.
Any thoughts?
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
Alpenliter
Fulltimer: Wherever we are!
Posted: 06/18/12 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't worry about that small amount of water in the bottom of the tank. It's aluminum, so it won't rust. The anode rod acts as a magnet for the minerals in the water to prevent interior corrosion. If you were to refill it and forget it, the tank could freeze and split and you would have worse problems. Good luck!
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
ScottG
Bothell Wa.
Posted: 06/18/12 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
The tank on a Suburban is not aluminum, it's glass lined steel and that's why it has an anode and Atwoods (which do have aluminum tanks) don't.
Scott, Grace and Wesly
H0NDA eu2000i
Old-Biscuit
Across the USA
Posted: 06/18/12 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Your good.......
Just reinstall anode rod so that threads can't get damaged.
Also....if it's an electric/gas water heater, turn the AC breaker to electric element OFF.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
1775
NY
Posted: 06/18/12 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, it is steel and glass lined and not aluminum. It is gas with an electric starter switch to ignite the gas. The electric plug to the water heater is right next to the tank and looks like a circuit board connector on an electric cable running into the water heater. I pulled that plug so that there is no way it can come on if I accidentally hit the water heater switch. I can't pull the fuse as I learned last winter that it is shared with other electrical circuits that need to be on.
Thanks.
Alpenliter
Posted: 06/18/12 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I stand corrected.
Wadcutter
IL
Posted: 06/18/12 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
When I drain my tank and am going to leave it sit for a while I built an insert to use instead of the anode rod. Went to the local plumbing store and got a plastic threaded adapter. It has a male end for attaching a rubber hose with a clamp. Took a bit of screen wire and wrapped it around the end of the male end and then held it in place with a hose clamp. What this does is allow the tank to dry and it keeps out critters and bugs.
Camped in every state but Alaska
Kirk
Livingston, Texas.
Posted: 06/19/12 07:24am Link  |  Quote  |  Print  |  Notify Moderator
There is no problem at all with what you are doing. Consider what others do when they store the RV and leave the water heater tank empty? Exactly the same as you are doing. The steel tanks do not rust or deteriorate at all while sitting empty. You may want to sanitize the water system when you do refill the water heater and I would also remove the wire between the water heater circuit board and the spark probe to light the propane, just to insure that it can never be turned on while empty.
Good travelin! ........Kirk
Professional Volunteer
Fulltimer for 11 years,
URL: www.adventure.1tree.net
