RV.Net Open Roads Forum: Tow Vehicles: Tow Vehicle sorry guys onece again please
Search only in Tow Vehicles
 > Tow Vehicle sorry guys onece again please
Page of 6
drae0814
Sunny Cal
Posted: 06/18/12 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
I know you experts have been over this many times but I just sold my 3000lb Tent Trailer or PUP as you will. The dealer has sold me a wonderful trailer. They asked about my tow vehicle and just told me that I will be just fine the sale is done and the trailer is home so I own it. The trailer is a 03 Prowler LS 31G North West Edition with large slide. This is a non bunk house model and has a very large rear bath. Above the trailer sink on the sticker it says GVWR 8900 min UVW 6899. I have a 05 DODGE HIMI 5.7 1500 with the Tow package button on the gear shift. I went on the dodge site and it lists my truck at 13,850lbs with a tow rating of 9150. i have a class 3 receiver that says 10,000 with WD I am using the Weight Distribution hitch system by Draw Tite with a draw tite sway bar, a separate unit,i am also using a Prodigy Brake Controller. the Pup was very easy to pull I can feel that 6000 + pounds back their but truck RPM around 2 1/2 temp is low so it feels OK, I have a little water in the black tank and 1/3rd in the fresh i only camp in full hook up area and with-in 20 to 50 miles of my house as i am only 42 years old and have a full time job so I can only camp 4 to 6 times a year. it looks like I won't be retiring for another 30+ years. OK back on track The sticker on my Dodge truck door says Front 3,700 Rear 3,900 need some help with that. I don't know what the rear gears are on the truck, maybe a little help their as well. I guess the bottom line is am i safe. i am not towing much gear i would say right around 250 lbs just a guess and my Wife we are light so add another 300 for the 2 of us and the tow bar hitch is heavy not sure on weight. and last question when towing do i keep the truck in the tow mode i have only been using it on hills. temp has not moved thanks for any help as i enjoy rving and want to keep on enjoy for years to come and don't really want to mess my truck up.
Post moved from TT Forum to Tow Vehicle Forum
Moderator - TT Forum
* This post was last edited 06/19/12 07:18am by an administrator/moderator *   View edit history
M GO BLUE
Southgate, MI
Posted: 06/18/12 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
A 1/2 ton gas truck pulling a 31' TT? Wow...more than likely you will be overweight...may even have a case of the "tail wagging the dog"
Been there and done that...never again for me
Can you tow the TT? YES
Can you tow the TT safely? Not likely...
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
drae0814
Sunny Cal
Posted: 06/18/12 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
Yes i here you their, i keep truck right around 50 to 60 MPH stopping and acceleration feels good i took it up to 70 just to here engine but don't worry guys i know that is not a proper tow speed just testing truck in a open area. and when on FWY I have very little sway at all if any while changing lanes or being passed but i have only pulled it about 80 miles 2 camp trips so far this year.
enjoy life while you can
05 Dodge HEMI Quad Cab
03 Fleetwood Prowler 31G LS North West Edition
Draw Tite Weight Distribution ans Sway Unit
90885 Prodigy Break Controller
tomdinwv
WV
Posted: 06/18/12 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
I can't help you out with the numbers, but there are others on here who will do that. I was in the same situation as you. I bought a 30 TT, dry weight (which means very little) is approx 6900lbs loaded up and ready to go with all tanks empty, I guesstimate it weighs around 8200lbs, give or take. I had an 08 Ram 1500 which of course the TT dealer said was fine. Towing was not enjoyable to say the least. Never had problems stopping or driving on two lane roads but on the interstates, it was not fun at all. Big trucks passing would shove me all over the place and bumps would make it porpose. I hated towing on the interstate and would do everything I could to avoid it.
I ended up trading in the 1500 for a 2500 Ram. World of difference. The truck/TT is now stable on the road. No push from big trucks and the porpoising is gone. I never had a problem with swaying but I never was caught in "high" winds while towing with the 1500 either. You may eventually become uneasy as I did and feel the need for a heavier duty TV. Made a world of difference for me. Good luck!
SWD
Land of Living Skies
Posted: 06/18/12 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Too smaller truck for this TT. Upgrade TV.
MackinawMan
NW Ohio
Posted: 06/18/12 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Sure sounds like it...especially if you load that truck with gear and people.
2000 Ford F350 XLT 7.3L PSD CC 4x4 OffRoad SRW Long Bed
2008 Jayco Eagle 314BHDS (Momma Eagle)
Equalizer Hitch System (1400/14000lbs)
Curt XD Class V Receiver Hitch (1500/15000 lb)
donn0128
Pronounced Ore-gun
Posted: 06/18/12 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
I'd say get yourself to the scales when everything is loaded for a trip and see where you are. I think you will be borderline but OK.
BTW, I just don't understand how towing short distances will make any difference if your overloaded? same for the towing slow? It just does not compute, Towing overloaded is towing overloaded no matter if you are only going 5 miles or 25 MPH it is still unsafe.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Terryallan
Foothills NC
Posted: 06/18/12 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
As stated many times. You run out of weight long before you run out of length.
For your truck to tow the 9150lbs you stated. Your truck would only be able to weigh 4700lbs. I bet it weighes more thn that. I bet your Tow capacity is much closer to 8500lbs. You figure that by subtracting your truck weight from the GCVWR, of 13850lb which you posted.
IMOP, You prolly have too much weight for your truck, unless you don't plan on carrying anything (family) in the truck, and can get away with only 500lbs in the trailer.
As mentioned. Get everything weighted, loaded, ready to camp. You may come in just under the wire.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
Charltons
Battle Ground, WA
Posted: 06/18/12 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
X2......3/4 ton at a minimum.
2012 Dodge Ram 2500 Crew Cab 4X4 TCD
2012 Keystone Sprinter 311BHS
boosTT
Milwaukee
Posted: 06/18/12 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
That's a big and heavy trailer for a 1500. But, since your towing short distances, you may be okay. Distance matters because if it's too windy you can wait it out or avoid the interstate. It also helps if you know the area and are not trying to read road signs and need to slam on the brakes.
Page of 6
