RV.Net Open Roads Forum: Tow Vehicles: Thanks
Search only in Tow Vehicles
 > Thanks
haste maker
alabama
Posted: 06/18/12 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
To all the people that told me about the PacBrake...I just got back from a trip after installing the PacBrake...what a great brake, it made the trip so much better than before the PacBrake
Retried Teamster
2007 Dodge
2012 Sierra
2002 Honda Goldwing
ScottG
Bothell Wa.
Posted: 06/18/12 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Your spoiled now and you'll never be able to go back to living without one!
Mine has been great too. We travel over two mountain passes on a regular basis with our TT and it makes coming down the hills a pleasure.
Enjoy!
Scott, Grace and Wesly
H0NDA eu2000i
bailer6334
Prescott, AZ
Posted: 06/18/12 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
FYI, I'm glad your having better luck with yours than I did. I had a RAM 2006 5.9L diesel and installed one in 08. Worked great for the first 1+ year, than would stop working in the Arizona desert. Called the factory and was told they would not work above 110 degrees and to move it from the top of the engine to the passanger inside fender. Moved the compressor and got significant vibration and still cut out intermittently. Called the factory again and was told mine was only the second RAM of that year to have the problem and it must be in the RAMs on board computer. So sorry could not help. Good-by.
While I didn't have a very good experience, they are still a good unit on most trucks.
2011 Arctic Fox 29-5T 5th Wheel
2011 Silverado HD 3500 6.6L Duramax Diesel Crew Cab
Short Bed 4X4 SRW LT
50gal Transfer Flow Aux. Tank
16K Valley Hitch w/bed saver
45Ricochet
North Idaho
Posted: 06/18/12 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting I've not heard that before. So it is the compressor or what? I mean 110* is nothing under the hood. I know the Jacobs has been known to have pump issues after many thousands of miles, but nothing to do with heat. Something sounds wrong to me, I'd give em another call.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
bailer6334
Prescott, AZ
Posted: 06/18/12 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
45,
It was the compressor. As relayed above this is what they told me. Don't have to worry about it anymore as I have a intergrated EB on my new Chevy. BTW, I have used the new EB thru the Eisenhowser Tunnel I-70 both towing my 12K 5er and empty and it is fantastic. Never touched the brakes either side both towing and not towing.
45Ricochet
North Idaho
Posted: 06/18/12 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
bailer6334 wrote:
45,
Yeah I've known the feeling on that road since 2006 also. Some of the bigger grades I do need to use the service brakes though
 > Thanks
