RV.Net Open Roads Forum: Towing: Ball height compared to coupler height
Search only in Towing
Open Roads Forum  >  Towing
 > Ball height compared to coupler height
BenK
SF BayArea
Posted: 06/19/12 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Bottom line is where it ends up when finished fine tuning
The trailer should be level at it's highest pointing and I like slightly pointing
down
The TV orientation is no longer the old rule of thumb of even drop. Follow your
glove box manual, as there variations from OEM to OEM
-Ben Picture of my rig
MitchF150
Washington, the State
Posted: 06/19/12 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I was really amazed how much of a difference just lowing my hitch setup one hole to the bottom most hole made in towing my little trailer.
It's now just a tad low on the nose when it's all hitched up and ready to roll.
Before, it was essentially 'level' by eyeballing it when it was on level ground...
Just what worked in my case, as yours my differ, but my vote would be better to be nose low if you have to pick an 'either/or' situation.
Good luck!
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
ttommyy48
NW Ohio
Posted: 06/19/12 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
You can also get a hitch ball with a 1" rise. Your standard ball is approximately a 1/4" rise, so the 1" would net you approx. 3/4" if you need it. I got mine from etrailer.com.
YMMV
chevor
US/Canada
Posted: 06/21/12 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
I dont like this arguement that the trailer has to level. I dont care if the trailer looks pretty going down the road. I adjust my hitch so the trailer and TV are at there greatest stability. I dont agree that level is always best, it varys trailer to trailer
2010 Gmc 2500 Duramax,1ton rear springs, 90g box tank, 0ver 490,000 Odometer miles, 20k Curt fifth wheel, 18k Curt rear mount hitch. Cobra CB/Weather Radio, Bridgestone Duravis R500 HDs Rancho 9000 Shocks, Firestone Airbags, bypass oil filter, Fass 95HD
bartlettj
Forest Grove, OR
Posted: 06/21/12 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
With a tandem axle trailer, you need it level enough that the weight is equally spread to all 4 wheels by the springs and equalizer bars.
goducks10
Keizer OR
Posted: 06/21/12 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
FWIW, my TT with spread axles is 2"+ low in the front and has the same weight on both axles. I weighed it on our last trip 2 weeks ago. Both axles were 3250lbs. I wonder how far nose low I could go before the weight would change.
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/22/12 05:09am Link  |  Quote  |  Print  |  Notify Moderator
It doesn't matter where you start out at, only where you end up. Adjust the ball height to whatever height is necessary for the trailer to be level, or slightly nose-down, once everything is hitched up and adjusted. You don't want the trailer to be nose-up.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
tsduke03
Iowa
Posted: 06/22/12 06:37am Link  |  Quote  |  Print  |  Notify Moderator
It matters where you start out at when the camper isn't at home. I might get lucky and not have to adjust anything when i go to pick it up next time. Yeah right.
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/23/12 10:18am Link  |  Quote  |  Print  |  Notify Moderator
LOL No one can reasonably expect to properly set up a hitch when the trailer isn't even in the vicinity!
