RV.Net Open Roads Forum: White hose and connecting to water spigot for first time
 > White hose and connecting to water spigot for first time
jas.az
AZ
Posted: 06/18/12 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone, long time lurker, first time poster.
We recently bought a toy hauler and I have two questions.
First, the trailer came with a white hose for potable water but I have no way of knowing if the previous owner used it only for potable water as he should have. I would feel better if I cleaned and disinfected it somehow. Do you all have a method for doing this or would you pitch it and buy a new one?
Second question, I'm connecting up to a potable water source for the first time (usually boon dock and use the water pump). If I remember right, I'm supposed to put a regulator on the spigot to protect my plumbing, right? Any other tips?
Thanks!
Macktee
Canada
Posted: 06/18/12 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Rather than try to clean the hose, use it for the black tank flush if you have one. Buy a new hose for your fresh water, just to be on the safe side. As for the regulator, many people use them as do I when the pressure is too high. I run the hose for a minute to check the flow. Happy Camping. Macktee
04 Monaco Dynasty Diamond 1V ( Homer II)
2012 Ram 1500 4X4 Quad Cab towed
2011 Dodge Journey
2013 Cargo Mate 24ft enclosed car hauler
Tom and DW Nancy
Holliday Trails member
Good Sam Life time member
FMCA member# F419937
bass n bob
new york state
Posted: 06/18/12 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
buy a new hose - cheap insurance against spending a day on the toilet. I get a new one every year.
definitly get a regulator- saves a bigger problem if the pressure is too great.
4x4Bob
California.
Posted: 06/18/12 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
I would get a new hose. However, you could mix up some bleach in a gallon of water and pour it into the hose. After connecting the ends, coil it into a 5 gallon bucket. Then pour more bleach water over the hose. Let it sit for a few hours. Rinse the out side and then run some water through the hose.
Yes, it better to hook up a pressure regulator that is set at 45 PSI or get one of the more upgraded Watts units that are adjustable. You never know what the water pressure in a park is or if it will surge during the day.
Spray the faucet with a bleach mixture and let it sit for a few minutes before you hook up your regulator.
Bob
2001 2500 Silverado LS 4x4 6.0, 4.10
2007 Jayco Eagle 288RLS
Cocktails for 6, Dinner for 4, Sleeps 2
End of dirt road, no signs in sight, sun going down: I am not lost, just getting ready to go camping.
wildtoad
Blythewood, SC
Posted: 06/18/12 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
White hoses are cheap. Get a new one. I have always assumed the previous owner DID NOT do things properly. They did not perform maintenance on any of the systems or chassis. It may cost me a few bucks but then I know things are the way I would want them.
And yes invest in a regulator. And a filter too.
Tom Wilds
Blythewood, SC
2000 Hurricane 30Q
dupreet
High Point, NC
Posted: 06/18/12 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
If you are worried, an 1/8 cup of bleach and some water poured in the hose, connect the ends, shake, let sit 10 minutes, rinse.
I can't fathom how many water hoses, faucets, drinking fountains, hotel glasses, etc., I have drank from in the last 47 years! I wouldn't sweat it.
As far as getting a new one and using the old one for a non-potable hose; I'd mix them up for sure. If you get a new one, either clean and save the old one as a spare or extra, or, leave it behind at your next campsite for the next guy to use (might be me )
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
ch-ta
MN
Posted: 06/18/12 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Definately buy a new hose. They really are cheap. As a previous post said, use the other hose to flush the black water tank.
I would also invest in a water pressure regulator. Much cheaper than gambling without one and losing.
2012 Chevrolet Silverado 2500HD CC 4WD LTZ
2013 Keystone Sprinter 266RBS
trnfla
Tampa
Do not do this... Throw it away and buy a new one... If you have 2 white hoses you might mix them up and its not worth the risk.
Please say a Prayer for my 5 year old Granddaughter (Discovered she had Leukemia at 9 months), she has been in remission and tests keep coming back clean.
Now 2004 Winnie Minnie 31C
Had 2007 Zeppelin 190 Hybrid,
1999 30' Dutchman Classic FW
NiceCamps.com
dodge guy
Bartlett IL
Posted: 06/18/12 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Every spring when dewinterizing my trailer I put the hose in one of my coolers mixed with water and bleach. I put the hose in so the bleach/water mix will be inside the hose. 9 years and I still have the same hose in excellent shape. I wouldn`t use it for the black tank flush as was mentioned....you wouldn`t want to accidently mix them up!!! I have a cheap generic blue hose for the flush.
Are you filling your frshwater tank from a community spigot? or are you just hooking up to your sites spigot? you don`t need a regulator to fill your fresh water tank! depending on the water pressure at the campground you may or may not need a regulator. I have one, but have stopped using it. it cuts down the water pressure too much, to the point the water will just barely spray out of the shower!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
pbitschura
SE MN
Posted: 06/18/12 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
I'm amazed. Disinfect and forget it. If you don't trust bleach, use Limeaway or some caustic drain cleaner, then bleach. Cleaned organophosphates out of labware for years .Extreme paranoia here, IMO.
1988 Mallard class c 24' Chevy chassis 350 cu gas.
