RV.Net Open Roads Forum: leveling blocks.. can u use them under jacks
 > leveling blocks.. can u use them under jacks
rvgrammady
San Francisco Bay Area, California
Posted: 06/18/12 07:33pm Link  |  Print  |  Notify Moderator
I've heard pro's & con's on using the leveling (yellow or orange) blocks under the jacks on 35' RV. some say they break others use them.
Or what is your fix for placing something under the jacks so they don't sink into the ground or some say you need them on asphalt also?
Help.... sorry if this is the wrong forum for this question.
1997 Allegro Bay 35' Chevy
1998 Saturn SW2 Wagon, Automatic
Blue Ox Aventa II, Patriot Brake
"We'll be friends until I'm old and senile, then we'll be new friends."
ch-ta
MN
Posted: 06/18/12 07:44pm Link  |  Print  |  Notify Moderator
we use the orange (Lynx) ones. They are easy to keep clean and take up very little storage space. Also wood holds moisture, where the levelling blocks are easy to dry off before packing them away. They are lighter also.
I have heard of them fading and cracking, but the warranty and customer service on this particular brand is great. Though I have never had an issue with them yet, I've seen reviews where others have had them easily replaced by the manufacturer at no cost to them.
I have a much smaller and lighter TT than what you have though.
2014 Bridgeview BV-40CK2BH (Park Model)
pulsar
Lewisville, NC
Posted: 06/18/12 08:20pm Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
trike2
idaho
Posted: 06/18/12 08:23pm Link  |  Print  |  Notify Moderator
I have used the lynx supports for five years and never had a problem with them, I have two sets as at times I need to place two, three under the wheels to lever my fiver.
2005 gmc 3/4 hd, sb, 4x4, 8.1 gas/allison 17,000 and climbing.
2005 Lakota, by Monaco, 3 slds, 29f.
kalynzoo
Los Angeles , California
Posted: 06/18/12 08:55pm Link  |  Print  |  Notify Moderator
I often use the yellow plastic (leggo like) blocks under my jacks to either protect the ground or create a firmer surface. I carry two sets.
JCGibson
In the Missouri Ozarks
Posted: 06/18/12 09:01pm Link  |  Print  |  Notify Moderator
We have used our two sets for 6-7 years now with not problems. We use them under the wheels, front landing gear and back jacks. We have also used them when we had to load a low setting car on a car trailer. We placed the ends of the ramps on them so that the bottom of the care would not drag the ground. We have never had any problems with them.
John (USAF Retired) Cheryl (Mid School Teacher)
'16 Newmar Ventana 3709 Sold
'16 Tiffin Allegro 36LA traded
'11 Dodge 3500 Crewcab sold
'14 EverGreen Bayhill 295RL sold
'12 Voltage V3200 sold
'09 BigHorn 3400 sold
'06 Jayco Octane sold
'04 Jayco Baja sold
katoomer
Vancouver
Posted: 06/18/12 09:56pm Link  |  Print  |  Notify Moderator
We use them along with a few larger plywood blocks I made.
The plastic ones will break if the ground is uneven but they are cheap to buy.
2009 Newmar Ventana 3942
2010 Pace Shadow 18ft
2010 KTM 450 XCW six days
2010 Can Am Outlander 650 XT
2014 Can Am Outlander 500
2007 Yamaha YZ250F
1989 Douglas Skater 21' Twin 2.5s
sum1
So-Cal
Posted: 06/19/12 12:32am Link  |  Print  |  Notify Moderator
I use 1 1/8" plywood.
jomarfl
Tampa
Posted: 06/19/12 02:19am Link  |  Print  |  Notify Moderator
Use pieces of wood I believe were 6x6 with holes drilled for rope to pull out after we bring the jacks up. Have never used the plastic units.
2008 Fleetwood Fiesta
Tampa, FL
klm
SIOUX FALLS, SD
Posted: 06/19/12 05:53am Link  |  Print  |  Notify Moderator
We use 12" x 12" x 2" homemade wood jack pads. Took 2 1" boards - cross grained them together - glued/screwed, added pull handle (hook awning rod), painted with weather resistent gray. Don't use them all the time, but great when needed - just last night, we were in a cg that had a heavy rain - parked on dirt/gravel - cg required jack pads as the ground was soft.
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
