RV.Net Open Roads Forum: leveling blocks.. can u use them under jacks
 > leveling blocks.. can u use them under jacks
DrainSurgeon
Grand Rapids, MN
Posted: 06/19/12 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Did something like klm. Just cut four 12"x12" blocks from a left over piece of a laminated beam (2"thick). Painted them green and have used them when on a soft surface for years. You'll need something wider if you get on really soft ground but they work for me.
Weathertodd221
FL
Posted: 06/19/12 06:17am Link  |  Quote  |  Print  |  Notify Moderator
PT 2x12s scrap. Works fine on sandy/soft grass.
smlranger
Virginia
Posted: 06/19/12 06:27am Link  |  Quote  |  Print  |  Notify Moderator
I made some plywood pads, 12" x 12" and attached a piece of thick rubber mat to one side (it is cut from those big rubber mats you can get at Tractor Supply....horse stall mats I think).
2007 Country Coach Allure 470, 2012 Honda CR-V toad. SMI Air Force One braking system. Lucy the rescued lab/springer mix; Dixie rescued beagle mix. Smith Mountain Lake, VA
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 06/19/12 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Under each jack I use two pieces of 3/4" plywood cut into 12" X 12" squares and screwed together;.also have a small handle attached to it.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
rr2254545
Minnesota/New Mexico
Posted: 06/19/12 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Use wooden 2X6 as above, the plastic ones sink into the ground, note above those that use them are not the heavy class a motor homes.
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
TechWriter
On The Road
Posted: 06/19/12 07:52am Link  |  Quote  |  Print  |  Notify Moderator
I bought a set of plastic outrigger pads once I discovered that plywood delaminates when wet.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
rr2254545
Posted: 06/19/12 07:59am Link  |  Quote  |  Print  |  Notify Moderator
I am sure they are nice but for $137 I can replace my 2X6 17 times
rvrepairnut
bc
Posted: 06/19/12 09:01am Link  |  Quote  |  Print  |  Notify Moderator
2x12 is best. cheap and easy and very effective
Nomadac
Columbus, IN
Posted: 06/19/12 09:49am Link  |  Quote  |  Print  |  Notify Moderator
I bought 4 pcs. of rough cut oak 2 1/2" thick 13 1/2 wide and 24' long from a lumber mill, that I sealed to resist moisture. They increase the footprint of my jack pads on my asphalt driveway. My MH weighs 29K and I am sure would break plastic pads, especially if the ground was not level if used. Been using them for over 6 years with no problems. I attached a metal handle to position under jack pad and for carrying.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
down home
south
Posted: 06/19/12 09:54am Link  |  Quote  |  Print  |  Notify Moderator
I've got the orange ones. They deformed so badly on soft ground that they are useless under the jacks. They didn't pop back into shape.
Still got four of them in the coach. Went back to wood.
