goufgators
Crawfordville, Florida
Recently purchased a new Pressure Pro system and have a question that the instructions don't seem to address. When the MH is not going to be used for a month or longer, is it advisable to disconnect the receiving unit from the elecrical supply and remove the sending devices from the tires? Would that cause the sending units' batteries to last longer, or not?? Thanks for any and all replys. / Larry
Ivylog
Blairsville, Ga. USA
Yes, removing the sensors will increase the battery life. I use a strofoam egg crate to store mine in. This lets me keep track of where they go, but you need to put something on top of them from moving around as they are not as large as eggs. Be careful to not loose the red seal from inside of them. No reason to leave the power on to the monitor. I mounted my monitor so it's antenna is sticking up in the side window which lets me pick up my toad when it's more than 100' behind the MH without a repeater.
*Not sure how they will go to sleep when not moving as they work off of pressure, not motion. You can check the pressure in the tires a month after you parked it without moving it.
edited 06/19/12 06:57am by Ivylog *
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
Trap
Alberta
I never disconnect them except to store the coach over the winter and my sensors are going on to the 6th season. They should go to sleep when not moving.
I do turn off the monitor when not in use.
wolfe10
Yes, I disconnect the monitor when not in use, but that has no affect on life of sensors. But, no point in having that drain on the coach battery even though it is small.
While in storage, I also remove the sensors and put in small zip locks with labels as to wheel location.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
RCMAN46
NorthWest
For less than 6 months I would not recommend removing them. First they go into alarm when removed which will us a lot of battery on the sending units. Second each time you remove one that puts more wear on the gaskets which may cause future leaks. I have had mine 5 years now with original batteries and I have only removed them once to replace the tires.
Wherever I happen to park
The monitor does draw a bit of power so disconnecting when not in use is a good idea. Though if you store with shore or solar power not absolutely needed.
My one complaint against the pressure pro is that the batteries in the senders are NOT something you can replace. You have to trade the senders in on new ones.
While they are on the tire they send reports every few minutes, drawing battery power to do this.
Remove then and they scream for a couple minutes, but then shut up and go dormat, there is no off switch, this results in no battery drain (or very little) and extends the life of the sensor.
Thus removal of the wheel sensors in long term storage a good idea.
SUGGESTION.. Get an egg carton, common item.
Label each compartment LF, RF, RRO RRI LRO LRI (right/Left front/rear inner/outer) And put them in the egg carton as indicated.
IF YOUR TOWED does not have TPMS, move the receiver to that vehicle and set it for "Towed only" (Heck, can save you grief)
Chuck&Gail
In the Colorado Mountains
Sensor battery life affected some, but VERY little UNLESS they start alarming for low pressure. My monitor is wired so it turns off with key, you might check what yours does.
When our sensors are not on the TT, they get put on wifes car (yes we have two monitors). Other set is left on TV. Thus ours are pretty much installed 24x7x365. Been over 8 years now. Keep expecting to need new batteries, but so far everything is great.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
John Wayne
Long Beach, Ca
I also remove mine from the MH and the Toad (for the toad I remove at each campsite where I'm going to use the toad my senders stick out past the rim and I don't want to rip one off if I hit the curb parking) I keep mine in a plastic fishing lure box a small one thats divided into six compartments it has a locking lid use a marker and mark each square where the sender came off i.e. inside right rear, outside right rear. I have 2nd lure box for toad marked r/f, l/f, r/r,l/r.
Take a SMALL amount of anti-sieze and put it on the lip of the valve stem then when you put on the sender it will lube the seal on the sender so when you take the sender off and on there is less chance of tearing red rubber seal in the sender.
John & Carol Life members
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
Security by Bentley
God Bless
KF6HCH
Chuck&Gail
A bag of new sender seals are available for a very low cost from Pressure Pro directly if you need one.
