RV.Net Open Roads Forum: Fifth-Wheels: TrailAir or 5th Airborne?
 > TrailAir or 5th Airborne?
msjdbman
SW Michigan
Posted: 06/19/12 05:03am Link  |  Quote  |  Print  |  Notify Moderator
First...I hope I have this in the proper section. I have narrowed my search for a replacement pin box down to the TrailAir or the 5th Airborne. Both units seem like they will satisfy my needs. Has anyone had experience with both units? Pro and Cons to either unit? Thanks in advance.
2008 Duramax/Allison LT2 Crew cab Standard Box. Hellwig Air Assist.
2003 Coachmen Chaparral 295 IKS
DO N DAT
Antioch, Ca
Posted: 06/19/12 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Have no experience with either but, am leaning towards getting the Trailair, because it is made by Lippert, who made my frame. Also it looks like it would be easier to replace the air spring on the Trailair. Will be watching this thread for more input.
1999 Ford F350, 7.3 Diesel, 2003 Triumph 365L
eHoefler
ozark mountains
Posted: 06/19/12 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Either unit will be a good choice. I have the Trail-Air on our 40' fifthwheel. Works great and wouldn't be with out it. On one trip, we forgot to put away the little pump hand soap in bath room sink. It road there all the way to our next stop right where it was left, some 500 miles down the road. It know has become a challenge to see if it ever falls over or off the counter. It has been some 15,000 miles with out an incident, on some very rough roads, like around Oklahoma City!
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
jim87vette
Arizona
Posted: 06/19/12 07:16am Link  |  Quote  |  Print  |  Notify Moderator
I have the 5th and it works great.
08 GMC 3500 Dually Duramax
96 Chevy 2500 6.5
05 Yamaha Rhino
04 Gearbox 335FS 5er 14k wet
ken burke
usa
Posted: 06/19/12 07:18am Link  |  Quote  |  Print  |  Notify Moderator
I don't know which is best. I have the TrailAir, plus the lower jaw part of the TrailAir. It is hard to say how effictive the trailair really is, let alone how to compare with the 5th Airborne. It seems to me that I saw a post last year of someone that had experience with both.
About the only thing I can recommend is that you look at details of both, and make an educated guess on your own. Look at how the units are designed, and which seems to work the best. Which uses the best parts.
If you want a real difference is towing, get an air bag type of hitch. Expensive, but worth it if you can afford it. My guess is that an air hitch would cost $3000 or so.
ken
2011 Ford F-350 6.7 diesel, Crew Cab, LB, SRW, 4X4, White
Cedar Creek 34SB, 37 feet 5th wheel, Reese 20K Hitch
"So many questions, so little time."
RCMAN46
NorthWest
Posted: 06/19/12 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I chose the 5th Airborne because the air bag is protected from the sun. I spend the winter in Arizona so the trailer is in the sun a lot. also the 5th Airborne is better looking. I would expect the air bag to last at least 10 years so replacement ease should not be a factor.
Mile High
Denver, CO
Posted: 06/19/12 08:41am Link  |  Quote  |  Print  |  Notify Moderator
X2
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
JR45
Warren/OR/USA
Posted: 06/19/12 08:59am Link  |  Quote  |  Print  |  Notify Moderator
X3 on the 5th and here is the best place to get one with Free Shipping
http://tweetys.com/fifth-wheel-pin-boxes.aspx
2006 Country Coach Inspire 360 40ft Genoa Designer Series
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
98 Honda Accord Toad
msjdbman
SW Michigan
Thanks for the replies folks. I had been leaning towards the TrailAir, especially since a good friend of mine swears by it. Probably not a big difference between the two, and sun exposure on the air bag is not a concern to me. So unless I learn of a compelling reason to look at the 5th AIrborne....my decision may be easy.
Mile High
Denver, CO
Posted: 06/19/12 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Other than ugly - the Trailair is fine.
