RV.Net Open Roads Forum: Travel Trailers: Outside Kitchen Door Troubles
 > Outside Kitchen Door Troubles
NoDakAFRVr
North Dakota
Posted: 06/19/12 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2012 Bullet Premier 31BH. When the camper is stored (no stabilizing jacks down) the outside kitchen open and closes without problem. When jacks are down (even just slightly) it throws that door off for some reason to the point where I (wife) can't open it, and my husband has to wretch on it pretty bad to get it open. Has anyone else ran into this? Seems odd that after the trailer is leveled from all directions the door THEN gets offline and doesn't open well. It's the bottom left corner that gets so tight that holds it closed. This past weekend while out we did some playing around, (putting various jacks back up, only barely having them touch, to putting a bit more pressure on them than just stabilizing) and whenever those jacks are down is when the door gets thrown off. Thoughts??
~Em & Mike
Baby O
2013 Outback 250RS
2012 Keystone Premier 31BHPR
2007 Dodge Megacab 2500 Cummins
2007 GMC 1500 Sierra
<2012 many many years of tenting it!
2Macs
Indianapolis, IN
Posted: 06/19/12 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Take it back to the dealer you bought it from and let them resolve it. It's under warranty, so use it.
five'er
Canada
Posted: 06/19/12 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds to me like the frame is twisting much like a Tent trailers door does if it's not setup just right. I don't have an easy sollution other than to take it to the dealer and point out the flaw in design and if you can replicate I'm sure (or hope) they'd reinforce it somehow.
NoDakAFRVr
North Dakota
Posted: 06/19/12 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
We'll have to find a dealer in the state we live now, we purchased it in Michigan while "home" last Christmas, but we currently live in North Dakota. Guess it's time to find a local dealer for keystone!
GaryWT
MA
Posted: 06/19/12 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
Another option, although it does not fix the problem, is to open the door before you level the trailer.
ME '63, DW 64, (DS 89, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR
safn1949
Mankato,MN
Posted: 06/20/12 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2007 Hornet that we just bought and I find that I have to be careful how I tighten my stablelizer jacks as it will twist the trailer causing the door to open and close hard.But that is clearly stated in my owners manual that I read after some head scratching.
Also explains the cracks at the top corner of the door frame on my 91 and the 2007.
