RV.Net Open Roads Forum: Grrr... short holding tank vent thru roof on Itasca
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Grrr... short holding tank vent thru roof on Itasca
Executive
Posted: 06/22/12 01:19am Link  |  Quote  |  Print  |  Notify Moderator
The old adage, "If at first you don't succeed...." comes to mind. Like you, I prefer things neat and tidy....I would yank it off, learn from what I did wrong and redo it.....but...it's on the roof, you're the only one who is going to know it looks like crap.. (except the hundreds of us on RV.Net..) but I know it would still bug me....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
Jackha1949
Any Where USA
Posted: 06/22/12 06:32am Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem with my Itasca and replace the regular vent with a solar powered vent and have never had the problem again. Good Luck!
Jack & Peg
USN Ret AGC
K1ZMB
Sioux Falls, SD
06 Itasca Horizon 40KD
Pangaea Ron
Anacortes, WA, USA
Posted: 06/22/12 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the insight to my issue. I'm just waiting to get a few moments to get on the roof when it's dry and not in the dark... I'm trying to retire, but it's not going well.
I'll know who you are if I see you with a ladder propped against my MH... not quite how I want to meet other RV.netters. That also means you Gary.
2008 Itasca SunCruiser 35L
2000 Jeep Grand Cherokee Laredo
Pangaea Ron
Anacortes, WA, USA
Posted: 07/02/12 11:57am Link  |  Quote  |  Print  |  Notify Moderator
So here's what I did. I removed and cleaned the butt-glued vent pipe extension and Cyclone venturi vent that I had imperfectly installed.
I then tried pulling up on the vent pipe hoping that it would project above the roof, but it wouldn't budge.
I then slit a 10" long piece of thin-wall plastic pipe lengthwise and glued it inside a 3" long vent pipe extension with the top of both pipes flush. I then inserted the remaining 7" of the slit thin wall inside the existing vent pipe, and installed the Cyclone venturi vent in the normal manner with lots of caulking.
I'm much happier with this installation. Thanks for all the suggestions.
fourmat
NJ
Posted: 07/02/12 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Weathertodd221 wrote:
you can get a coupling to extend the pipe up. I would try to pull the pipe up first as suggested by fischer
thats the ticket
2009 Challenger
