RV.Net Open Roads Forum: Toy Haulers: Lift kit for a toyhauler?
Search only in Toy Haulers
 > Lift kit for a toyhauler?
rerod
Iowa
Posted: 06/21/12 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Boy.. Now I know why they want $1500
I just learned, yes it can occur even at my age, it's one thing to jack one side up. But a completely different song and dance with all the wheels off the ground. Sitting on a hill doesn't help either. Need to ditch my cheesy jack stands or place them on something big and flat.
1995 E350 6bt/nv4500, 2006 Featherlite 24' surv toyhauler, 2007 DRZ400s well farkled, 1985 Vmax stock, 1985 Vmax custom
nayther
Burbank, CA
Posted: 06/21/12 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, you need flat solid ground and GOOD jack stands. That's why I haven't fixed my fresh water tank because the thought of crawling under a 12,000# trailer sitting on jacks scares the******out of me.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
rerod
Iowa
Posted: 06/21/12 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
At least with your water tank the wheels are still on. It wont squish you..
Im getting 4 cinder blocks, leveled, with plywood on top before I attempt this again.
christopherglenn
a little over an hour from Yosemite
Posted: 06/21/12 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
rerod wrote:
christopherglenn wrote:
4x4x.25 box, with a crossmember above each axle. the crossmembers reduce the leverage of the framerails when turning.
If you look at the picture again, you can see stainless nuts which fasten the aluminum floor I beams to the steel channel the axles are bolted to. I dont have room for 4" x 4" x 1/4" tube unless I drill clearance holes for each SS nut. However a 4" x 2" x 1/4" would fit next to the SS nuts and still pass directly over the axle mounting flange. Do you guys think 4" x 2" set the tall way would be ok if I join/weld both sides with heavy 4" channel cross-members? The axle mounting bolts will be replaced with 6" bolts which pass through both 4 x 2's.
I might have to use 4 x 4 depending on availability.
My local shop wants $1500 to do this. The materials would cost me less than $200 since I have some of it and Im tempted to do this on my own and save $1300
You are refering to the nuts on the bottom of the frame to the left of the axle - mark and drill holes in the top of the 4x4 to fit over them like centering holes on an axle. If you drill both sides of the 4x4 you can still remove the hits with a deep socket.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
JIMNLIN
out here
Posted: 06/22/12 06:27am Link  |  Quote  |  Print  |  Notify Moderator
I have several 2' and 3' lengths of cut off railroad ties and several cutoff 5" x 5" pieces from barn poles that I prefere to use when lifting as heavy as a trailer.
Stack them at different angles to each other so the trailer doesn't roll off the blocks. Good luck.
'97 Park Avanue 28' 5er 11200 gvwr two slides
Dwight45
Kansas
Posted: 06/22/12 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Please don't use cinder blocks as jackstands! Just sayin!
Dwight
nayther
Burbank, CA
Posted: 06/22/12 08:57am Link  |  Quote  |  Print  |  Notify Moderator
My reason for concern is that I have to drop the axles so it would be supported only by jackstands, the truck, jacks, etc.
A short story on "cribbing" which is using things like RR ties, blocks, etc. A very well respected acquaintance was killed a few years back when his motorhome fell on him while he was under it doing suspension work. It was supported by dunnage (4x4's stacked in a box fashion like you see under houses being moved) nobody knows exactly what failed but it did, now Bert Elrod is dead.
That's why I haven't fixed my tank.
If you use something to support the trailer and you'll be under it I highly recommend you set up something that won't topple and then stack something else up as a "safety" or "stop" so that if your primary support fails the trailer will land on something besides you.
Bobwanderer may shed some light on this as he's worked for years on heavy equipment before his recent retirement.
big buford
Buena Park, Ca
Posted: 06/22/12 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Dwight
A BIG X2
04.5 GMC 2500HD D/A
06 38 CKS Dune Chaser
Chenowth 4-seat Subaru pwr
06 Rhino
06 Raptor 700
Beautiful wife that's much nicer than me
rerod
Iowa
Posted: 06/22/12 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Dwight
I picked up a bunch of 24 x 12 x 4" solid concrete pavers. I plan on leveling those and placing my jacks and jack stands on them. At the moment, Im still paranoid after what happened yesterday. The trailer moved about a foot to the left and I had to change my shorts. If the wheels had been off I woundnt be writing this.
rerod
Iowa
Posted: 06/22/12 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
I made some headway this afternoon. I need to add jacks on the front corners yet. But its pretty solid because it sits on all three supports. In fact there isn't a hint of sway and it feels like your inside a house. Second picture shows how far the trailer moved. Suggestions?
