RV.Net Open Roads Forum: Toy Haulers: Lift kit for a toyhauler?
Search only in Toy Haulers
 > Lift kit for a toyhauler?
rerod
Iowa
Posted: 06/27/12 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
More hard earned headway.. And ready for the axles.. Cross members welded in later.
1995 E350 6bt/nv4500, 2006 Featherlite 24' surv toyhauler, 2007 DRZ400s well farkled, 1985 Vmax stock, 1985 Vmax custom
nayther
Burbank, CA
Posted: 06/27/12 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
looks good so far
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
rerod
Iowa
Posted: 06/27/12 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Axles hung. Need to align the front axle and then mount the second parallel to the first. Rough heavy work..
The cross members will be welded in where the paint is removed. Still on the fence whether I need them..
* This post was edited 06/27/12 08:15pm by rerod *
nayther
Burbank, CA
Posted: 06/28/12 11:15am Link  |  Quote  |  Print  |  Notify Moderator
It is heavy work, even the EZ Flex was tough by myself. I STRONGLY suggest you tie these two channels together, too much twisting going on on a tandem axle when turning and with the additional "moment" provided by extending the axles below the frame you're asking for a twisted frame. I'm not a structural engineer (Mechanical degree) but I've taken some undergrad. classes enough to think this is a potential problem, besides you've gone to this much trouble, finish it "right".
Crazy Cooter
Redding, CA
Posted: 06/28/12 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
My feeling is that the Torflex axles are cross members in themselves. Its only 4", why bother?
If it were equipped with a leaf spring suspension, I would install at least two cross members.
Tony KI6WAO
2006 Dodge Ram 3500 DRW
1992 Jeep Wrangler YJ
2012 Cyclone 300C
2013 Can Am Maverick X-RS
2006 KTM 525 EXC CA Plated
2008 KTM 525 XC ATV
2008 Polaris 525 IRS
2007 Kawasaki STX12F
2009 Kawasaki 260X
rerod
Iowa
Posted: 06/28/12 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
nayther wrote:
I STRONGLY suggest you tie these two channels together, besides you've gone to this much trouble, finish it "right".
Good point. I'm just beat doing this alone. Between the 100+ temps today, and a aging body still sore from yesterdays 12hr day.. Im moving slow.. or,I'm pacing myself.
Question for you.. I replaced the short 5/8-18 grade 5 bolts, with 6" 5/8-18 grade 8 bolts.. What would you suggest for a torque on those eight bolts holding my axle's on?
Crazy Cooter
Redding, CA
Posted: 06/28/12 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Torque on a grade 8 5/8-18 bolt is 170-215, but you will likley crush your 2X4 tube spacer before that happens....it will then come loose at a later date. I always fished the shorter bolts in from inside the tube.
Then once the axle tracking is set, I weld a short bead to keep things form shifting.
rerod
Iowa
Posted: 06/28/12 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
So your saying I should have used the shorter bolts and fished them all? What torque would you suggest with the 4x4?
I plan on tacking everything up after I'm sure it doesn't dog leg.
nayther
Burbank, CA
Posted: 06/28/12 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't consider the torqflex, you might be right. However I'd still weld in a crossmember. Easy for me to say since I'm not doing the work huh?
Crazy Cooter
Redding, CA
Posted: 06/28/12 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
If you used 4x4, that would crush even easier. You need to weld in a tube insert for the bolts so the tube won't crush.
